How was the speed of light calculated before the redefinition of the meter?
In summary, the meter was originally defined as 1/10,000,000 of the distance from the equator to the pole, and the second was defined as 1/86,400 of the length of the mean solar day. As the measurements got better and better, it was decided to use a certain frequency of light emitted in an atomic transition to define the second, and then fix the speed of light and use that to define the meter. So the meter is no longer defined by a physical object like the Earth or a metal bar.
babaliaris
116
I'm reading a book from the authors Halliday and Resnick and it says that
Code:
The meter is the length of the path traveled by light in a vacuum
during a time interval of 1/299 792 458 of a second.
This time interval was chosen so that the speed of light c is exactly
c = 299 792 458 m/s.
I understand that, and it also make sense if you plug in these values into the dx formula of motion (you get dx = 1m)
but how did we calculate the speed of light in m/s very precisely before redefining the meter? The calculation of the speed depends in the previous definition of the meter right? So how does this new definition of meter can use the speed of light which was calculated using another definition of the meter? It does not really make sense to me...
You've correctly Identified the problem as being circular. Ultimately, units are arbitrary, so breaking the cycle simply meant making an arbitrary choice to fix one of the variables. The speed of light is the easier to deal with, so it was made the basis.
The wiki article on the definition of the meter describes some of that logic. For example, it immediately resulted in higher measurement accuracy for laser wavelength comparisons.
That's a fair reaction until you look at the bigger picture.
All units are defined by referring them to each other but the best quantities to hang the system on are those which can be measured accurately and reliably. Time (and frequency) are the best ones to start with because we can use atomic transitions in repeatable, accurate experiments to 'define' the second in terms of EM waves. Distance (the metre) hangs directly on that because we have confirmed that c is the same everywhere. c is the third value which can be reliably used in the x=ct equation.
Likes russ_watters
Code:
The meter was originally defined as 1/10,000,000 of the distance from the equator to the pole, and the second was defined as 1/86,400 of the length of the mean solar day. Given those, we can measure the speed of light in m/s. The meter was then changed to be the length of a bar of iridium that was stored somewhere in Europe. As the measurements got better and better, it was decided to use a certain frequency of light emitted in an atomic transition to define the second, and then fix the speed of light and use that to define the meter. So the meter is no longer defined by a physical object like the Earth or a metal bar.
Ohh I see. So the reason is that using the atomic measurement of time which is the most accurate measurement we have made, we use it with a less accurate measurement like the speed of light in order to redefine the meter more accurately. So the secret here is time, because we succeeded measuring it better we use it to redefine the meter better.
Did I got it right?
Likes sophiecentaur and Dale
Did I got it right?
I think so. Note that the speed of light is no longer measured, but is now defined, so it is known with no uncertainty. This web site has a lot more information and history.
Did I got it right?
Yes, that's how I've always understood it. But I went looking for the exact technical arguments for the change (which was made in 1983). The best detail I've found so far in that Google search is in the language of the https://www.bipm.org/en/CGPM/db/17/1/. Here are what I see as the key arguments in that resolution, though there are more (boldface is mine):
  • that progress made in the measurement of the frequency and wavelength of these radiations has resulted in concordant determinations of the speed of light whose accuracy is limited principally by the realization of the present definition of the metre,
  • that wavelengths determined from frequency measurements and a given value for the speed of light have a reproducibility superior to that which can be obtained by comparison with the wavelength of the standard radiation of krypton 86,
  • that a new definition of the metre has been envisaged in various forms all of which have the effect of giving the speed of light an exact value, equal to the recommended value, and that this introduces no appreciable discontinuity into the unit of length, taking into account the relative uncertainty of
    4 ´ 10–9 of the best realizations of the present definition of the metre,
From 1960-1983 the standard was a wavelength emitted by a particular atomic transition of krypton.
This is so awesome! I imagine myself hearing this in high school. When our teacher was saying something like that we where like "whaaat?" but now I get it.
Likes russ_watters
This was always happening to me at school. I would get only half of a message (sometimes my fault and sometimes the fault of the teachers) and I would often get a wrong idea about things. That could stick with me for years until another input would put me right. This is where Forums like PF come in handy - we have time to chew things over and improve our own understanding - and that of others (hopefully).
Likes babaliaris
1. How did scientists measure the speed of light before the redefinition of the meter?
Before the redefinition of the meter, scientists used a method called the Fizeau-Foucault experiment to measure the speed of light. This involved using a rotating toothed wheel and a stationary mirror to reflect a beam of light. By measuring the speed of the wheel and the distance traveled by the light, they were able to calculate the speed of light.
2. Who were the scientists involved in calculating the speed of light before the redefinition of the meter?
The Fizeau-Foucault experiment was first conducted by French physicists Hippolyte Fizeau and Léon Foucault in the mid-19th century. Later, other scientists such as Albert Michelson and Edward Morley also contributed to the measurement of the speed of light using different methods.
3. How accurate were the measurements of the speed of light before the redefinition of the meter?
The measurements of the speed of light before the redefinition of the meter were relatively accurate, with the Fizeau-Foucault experiment yielding a value of 298,000 km/s. However, as technology and methods improved, more precise measurements were obtained, and the current accepted value for the speed of light is 299,792,458 m/s.
4. What was the significance of the redefinition of the meter for the calculation of the speed of light?
The redefinition of the meter in 1983, which defined it as the distance traveled by light in a vacuum in 1/299,792,458 of a second, provided a more precise and consistent way to measure the speed of light. This allowed for more accurate calculations in various fields of science, such as astronomy and physics.
5. How is the speed of light calculated now after the redefinition of the meter?
Currently, the speed of light is defined as a constant value of 299,792,458 m/s, based on the redefined meter. This value is measured using advanced techniques such as laser interferometry and atomic clocks, which provide even more precise measurements than before.
  • Other Physics Topics
9K
12K
14K
