Thanks, Elucidus. Is the term "ordered n-tuple" synonymous with "n-tuple"? Your special definition of "
operator" sounds a lot like the definitions of "
operation" at Wikipedia and Wolfram Mathworld.
“Operation. Let A be a set. An operation on A is a function from a power of A into A. More precisely, given an ordinal number alpha, a function from A^alpha into A is an alpha-ary operation on A. If alpha=n is a finite ordinal, then the n-ary operation f is a finitary operation on A.” (Wolfram Mathworld [
http://mathworld.wolfram.com/Operation.html ]).
I take it a function could still be an operation in this narrow sense if the arity was 1, e.g. a mapping from the reals into or onto the reals. Here's another, broader definition I came across:
“Operation. 1. any procedure, such as addition, multiplication, set union, conjunction, etc., that generates a unique value [Unique to what? I’m presuming, by analogy with the definition of a function, unique to the input.] according to mechanistic rules from one or more numbers or values as arguments. 2. a function determined by such a procedure.” (Borowski, E.J. & Borwein, J.M.: Collins Dictionary of Mathematics). Would their Sense 1 be synonymous with "rule of assignment"?
For operator, I've found:
“Operator. 1a. any symbol used to indicate an OPERATION, such as the integral operator [integral symbol] and the differential operator [capital delta symbol]. b. the function determined by such an operation. 2. a MAPPING, such as a LINEAR OPERATOR” (Borowski, E.J. & Borwein, J.M.: Collins Dictionary of Mathematics). Following the trail of entries, they gives as synonymous: function, mapping and transformation, at least in some uses.
“Mapping or map. A function or transformation.” (Borowski, E.J. & Borwein, J.M.: Collins Dictionary of Mathematics).
“Map. The terms function and mapping are synonymous for map.” (Wolfram Mathworld [
http://mathworld.wolfram.com/Map.html ]).
“An operator [...] is [...] a mapping between two function spaces. If the range is on the real line or in the complex plane, the mapping is usually called a functional instead.” (Wolfram Mathworld: Operator [
http://mathworld.wolfram.com/Operator.html ]).
“Operator. The word operator can in principle be applied to any function. However, in practice it is most often applied to functions which operate on mathematical entities of higher complexity than real numbers, such as vectors, random variables, or mathematical expressions.” (Wikipedia). This one's especially helpful as it goes into some detail about the various naming practices, including notes to the effect that the term "operation" is also traditionally applied to a function that happens to have a traditional, commonly used symbol of its own, e.g. +.
For Davis & Snider, an operator is a name traditionally applied to "functions [...] that associate functions with functions" (An Introduction to Vector Analysis, sixth edition, 1991, p. 140). They (gently) deprecate the term operator for obscuring to beginners the broad application of the concept of a function.
