Deflection of Light Around Massive Bodies
DiracPool
I thought this would be an easy lookup. However, after farming several sources, I couldn't find a discussion on it..
Anyway, my question is is this, does a shorter wavelength/higher energy photon bend more around a massive body than a lower energy photon? For instance, if we had two photons, one high energy and one low energy, from a distant source moving around the sun at the exact same distance from it's center and we were measuring their deflection during an eclipse, would there be a difference in the amount of deflection between the two (that is, if the difference were measurable)?
My guess would be that the higher energy photon would be deflected more but I haven't been able to find a reference to it.
Also, a related question would be the "gravitational redshift" of said photons in the example above. That is, would each of these photons experience such a blueshift (in this example) as they were being deflected around the sun, and would the amount of that blueshift be similarly affected by their energy?
Looking at the deflection angle, and also at its derivation, I don't see where the momentum/energy of the photon goes into the game. It exists but it's replaced [with the angular momentum] by the impact parameter, that has a different physical meaning. So I guess no light will be deflected more or less, they will accept the same deflection if they are coming near the massive lens with the same parameters.
For your related question, check here
https://www.physicsforums.com/threads/gravitational-lensing-and-red-shift.382537/
Photons follow null geodesics. Once you've specified the starting event and the starting direction in 4D spacetime, you have uniquely specified the geodesic. The starting direction in 4D spacetime is uniquely determined by the starting direction in 3D space, because the time component then depends only on the speed, which is the same for all photons.
So all photons passing through the same event with the same spatial direction follow the same path regardless of frequency.
Likes bcrowell
Ok, got it. Thanks for the clear responses.
I seem to remember reading that the (lack of) dispersion of electromagnetic radiation with different frequencies has been tested by studying the deflection of radio signals from distant sources in the Sun's gravitational field.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
