Degree of coherence of light from a red semiconductor laser
The coherence of light from a 1 mW red semiconductor laser can vary significantly, with coherence lengths reported between 1 mm and 300 m depending on the model. This variability makes it difficult to determine coherence properties without manufacturer specifications or direct measurements. For measuring spatial coherence, a Young interferometer can be used, while coherence length can be assessed using a Michelson interferometer. Additionally, coherence properties can be inferred from the spectral bandwidth and beam characteristics. Ultimately, precise information requires either manufacturer data or experimental measurement.
htg
I would like to have at least a vague idea how coherent is light from an inexpensive 1 mW red semiconductor laser which I have.
I tried to find the manufacturer using Google, but I haven't found it.
I would like to know the coherence length and the degree of spatial coherence.
Is there anyone who may give me some information?
Science news on Phys.org
It is not possible to get that information anywhere other than either the manufacturer or direct measurements. Even for a single manufacturer with different versions of the same model of laser you can get coherence lengths ranging from 1 mm to 300 m.
http://www.crystalaser.com/new/greenlaser.html
DaleSpam said:
... you can get coherence lengths ranging from 1 mm to 300 m.
1mm already is a decent coherence length, because it is >>> λ.
But what about spatial coherence?
You missed the point. My point was that even minor variations in the model can give you coherence lengths which vary over 5 orders of magnitude.
There is simply no way that someone on an internet forum can answer your question. You either need to measure it yourself, or get the specifications from the manufacturer.
I think if they call it a laser diode, there should be decent lower limit of coherence length (which should be >> λ ) and there should be significant degree of spatial coherence.
Do you have a suggestion how I can measure spatial coherence and coherence length?
htg said:
<snip>
Spatial coherence is usually measured by a Young interferometer, letting the slit spacing vary. Coherence length can be measured with a Michaelson interferometer, letting one arm change in length. The variation of fringe visibility is a measure of the coherence properties.
One way to infer the coherence length is to measure the spectral bandwidth of the output, and IIRC you can infer the coherence area by measuring the size of a single 'speckle'. Finally, both can usually be calculated from manufacturer's specifications: the output spectral FWHM, the beam diameter at the output face, and the beam divergence.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
