Delta function potential; Schrodinger Equation
3 replies · 4K views · last reply
unscientific
Consider the TISE for a particle of mass m moving along the x-axis and interacting an attractive delta function potential at origin:
Part(a): What is the difference between a bound state particle and a free particle?
Part(b): Show ##\psi _{(x)} = exp (-|k|x)## is a solution of TISE, given conditions:
Part(c): Explain why symmetric solution is of form:
Part(d): Use boundary conditions to show the following:
Part(e): Investigate this solution graphically
Part(f): Find the significance of this result
Part(a)
A bound particle as energy E<0 while a continuum eigenfunction gives energy E>0.
Part (b)
TISE is given by:
[tex]\hat {H}\psi = E\psi[/tex]
Using first boundary condition provided we get
[tex]2k = \frac{\lambda}{a}[/tex]
Substituting ##\psi = e^{-k|x|}## into TISE and using what we have just found:
[tex]-\frac{\hbar ^2}{2m}(\frac{\lambda}{2a})^2 - \frac{\hbar ^2 \lambda}{2ma}\delta_{(x)} = E[/tex]
I'm not sure why the delta function goes to zero here?
[tex]E = -\frac{\hbar ^2}{2m}(\frac{\lambda}{2a})^2[/tex]
Part (c)
For |x|>a, V = 0:
[tex]-\frac{\hbar^2}{2m}\frac{\partial ^2 \psi}{\partial x^2} = E\psi[/tex]
Solving this equation gives an exponential ##\psi = exp (-k|x|)##.
For -a<x<a, the particle is bounded and symmetric about origin so ##\psi \propto exp(kx) + exp(-kx)## which is ##\propto cosh(kx) = A cosh(kx)##.
Part (d)
Boundary Conditions:
At x = a, ##\psi_{|x|<a} = \psi_{|x|>a}##.
Thus we get:
[tex]e^{-ka} = A cosh (ka)[/tex]
Second boundary condition:
At x = a, ##\frac{\partial \psi}{\partial x}_{left} = - \frac{\partial \psi}{\partial x}_{right}##
The delta function gives opposite gradients about a.
[tex]e^{-ka} = A sinh (ka)[/tex]
Using boundary condition earlier,
[tex]tanh (ka) = 1[/tex]
[tex]tanh(ka) = 2 - 1[/tex]
Can I simply substitute in ##2k = \frac{\lambda}{a}## here?
[tex]tanh(ka) = \frac{2ka}{ka} - 1[/tex]
[tex]tanh (ka) = \frac{\lambda}{y} - 1[/tex]
Part (e)
We can see that ##y_0 < \lambda##.
Since ##tanh(y_0) < 1##, thus ##y_0 > \frac{\lambda}{2}##.
Since for x≠a both delta functions are positive, it implies that the second term corresponding to the two delta functions ##\delta_{(x-a)}## and ##\delta_{(x+a)}## in the Schrödinger equation are >0. Thus the total energy subtract that is less than ##-\frac{\hbar ^2\lambda^2}{8ma^2}##.
Part(f)
Two delta function corresponds to electron being attracted to the two protons in nucleus (which is more massive so can treat as stationary). This is a more stable (favourable) configuration, so
[tex]H + H^+ \rightarrow H_2^+[/tex]
Part(a)
Part (b)
TISE is given by:
You're verifying the solution for x>0 and x<0. At x=0, there's a cusp, so ##\psi''## isn't defined, so the Schrödinger equation doesn't really apply.
Part (c)
For |x|>a, V = 0:
Part (d)
Thus we get:
This isn't correct. Integrate the Schrödinger equation between ##x=a-\varepsilon## and ##x=a+\varepsilon## and take the limit as ##\varepsilon \to 0^+##. This will yield the proper boundary condition on the derivatives.
Part (e)
Part(f)
So the equation##exp(-k|x|)## here only applies when x≠0. We can't find out what the solution is when x = 0? Is it because due to the nature of the delta function it is a sum of infinite series at x = 0?
But graphically you can see that it is symmetric about 0. You can also see that at x-ε the gradient is opposite that of at x+ε.
At x=0, the lefthand side of the Schrödinger equation isn't defined, so it doesn't really tell you anything about ##\psi##. The continuity requirement, however, allows you to fill in the hole at x=0.
It may look that way in the picture when you have a single delta function, but this time you have two. You no longer have the symmetry you had before. You need to justify the boundary condition mathematically.
