Measure Density Precisely w/ Waterproof Balance: Price Guide
To measure density precisely, especially under water, an accurate method for determining volume is essential, as mass can be easily measured. Pycnometers are commonly used for measuring the volume of liquids and solids, with specific devices available for each type. For solids, Archimedes' principle can be applied by submerging the sample in water and measuring the displaced volume, which can yield about 1% accuracy. Alternative methods, such as measuring the speed of sound in the material, may also be considered, but they present challenges in measuring dimensions. Overall, selecting the right instrument and method is crucial for achieving precise density measurements.
exponent137
How to measure density as much precise as possible. Possibly with a waterproof balance under watter.
What the prices are?
Density of *what*- gas, liquid , solid, powder, ...
I think density of solid. Piece of steel or..
Then what you really need is an accurate method of determining the volume- the mass is easy.
Pycnometers measure volume, and there are commercial devices that are used for solids:
http://en.wikipedia.org/wiki/Gas_pycnometer
I'm more familiar with the use of a pycnometer for the volume of liquids, and most of the gas ones seem geared towards powders/porous materials, but calling some of the manufacturers should point you to an appropriate instrument.
Failing that, simply follow Archimedes' idea: place the sample in a full beaker of (degassed, distilled) water, collect the overflow and weigh it- since you know the density of water, you then know the displaced volume. I bet you could get 1% accuracy this way, easily.
Perhaps you could actually manufacture a cuboid to high dimensional tolerance (for volume) and then measure its mass. Using a 'Eureka Can' isn't a very accurate method of volume measurement.
There may be other approaches, like measurement of the speed of sound in the material. You would still have the problem of measuring dimensions unless you could somehow measure the reflection at the interface with a known substance.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
