What is the Density of a Carbon Atom with a Concentrated Mass in its Nucleus?
The discussion revolves around calculating the density of a carbon atom, assuming all its mass is concentrated in its nucleus, which is modeled as a sphere with a specified radius. The user provided the mass of the carbon atom as 2.0 x 10^23 grams and the radius as 1.5 x 10^5 picometers. Participants emphasized the need for proper units in the calculations and the importance of using the density formula, d = m/v. There was a request for clarification on the units used and guidance on converting them before performing the final calculation. The user expressed gratitude for the help and indicated a better understanding of the problem.
omni
think that all the mass of the atom are concentrate in nucleus
and the shape of the nucleus is like a ball with
radius =1.5*10^5. IF the mass of the carbon atom = 2.0*10^23.
what is the density of the carbon atom?
the volume of the planet Earth=4/3pie*r^3
i just want to say that my English is not so good so i hope u can understand my question.
thanks you all.:smile:
Welcome to Physics Forums,
From now on, use the template given for homework help problems. You have given us the problem statement, now what are some relevant equations that would apply here? Also, most importantly, show us your attempt. What have you done so far on this problem?
You have stated a mass and a volume without units, which means these numbers are meaningless. WHAT UNITS are the mass and radius in?
What is the definition of density?
hi thanks for ur remark.
ok so the units is:radius =1.5*10^5pm
the mass of the carbon atom =2.0*10^23.gr
i tried to use in this formula: d=m/v
m=mass
d=density
v=volume
i did like this:d=2.0*10^23.gr/1.5*10^5pm.
and i not sure if i right.
i will be happy for any help that i can get :).
Does .gr mean, "grams" or...? :confused:
Your calculation steps are right so far, but you need to
1) actually calculate the final answer, and
2) express it in some reasonable units. For example, density is often expressed in kg/m3 or g/cm3. Do you know which units you are expected to use?
EDIT: In fact you have to decide (2) before you do (1), since you need to convert the numbers into the desired units before computing the final answer.
ok i will try to keep from here alone thank you really much i think i understand this question.
:smile:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
