Depth of a finite square potential problem
The discussion revolves around calculating the depth of a finite square-well potential needed to contain three energy levels for a particle with a mass of 1.88 GeV/c². Key formulas mentioned include the penetration density and energy level equations, with suggestions to use the standard parameterization for bound-state energy levels. The minimum value of the potential depth (u₀) is determined by plotting a specific function related to the energy states. Additionally, there is a recommendation to approximate the energy as if it were in an infinite well for more accurate calculations. The conversation highlights the complexity of the problem and the need for a deeper understanding of quantum mechanics principles.
aglo6509
Consider a finite square-well potential well of width 3.00x10-15 m that contains a particle of mass 1.88 GeV/c2. How deep does the well need to be to contain three energy levels?
I think I have to use the formula for penetration density:
δx=(hbar)/(sqrt(2m(V0-E)))
V0=0 because the particle is inside the well.
Would I use:
En=(n-1/2)(hbar)ω to find the energy of three levels?
Then would I plug this formula back into the penetration density formula to find the penetration density?
Thank you.
You know how the bound-state energy levels are calculated right?
The third bound state will be the second symmetric state.
So why not use the standard parameterization?
Plot y=v\tan v - the value of v where the second curve hits the v axis is the minimum value of u_0 to contain 3 states, and:
u_0^2 = \frac{mL^2V_0}{2\hbar}
Don't think this counts as introductory physics though.
I believe you need to approximate the energy as if it were in an infinite well:
E=n2(hbar2)(π2)/(2mL2)
with n=3
@aglo6509: how did you get on? As you see, you are attracting attention 8 months later ;)
@markovcy: welcome to PF; it is nice of you to start out by answering questions.
Under "get posts" at the top, there is an option to look for recent posts that have yet to be replied to - just saying.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
