Deriving EM Energy: Calculation & Explanation of E-Field Energy Storage
The discussion focuses on the calculation of energy stored in an electric field, specifically addressing a term in the integral that approaches zero. It explains how, without the potential V, the integral would yield a constant value according to Gauss's Law. However, when V is included, it decreases with distance, leading the integral to zero as the radius approaches infinity. The behavior of the integrand is analyzed, showing that while the integration contributes an r^2 term, the decay of V and E ensures the overall function approaches zero. The explanation clarifies the limiting behavior of the terms involved in the integral.
Swapnil
The following wikipedia article derives the energy stored in an E-field (under "Energy stored in an electric field"):
http://en.wikipedia.org/wiki/Electrical_energy
I don't quite get how the following term goes to zero in the article?
\frac{\epsilon_o}{2}\int V\mathbf{E}\cdot dA
First consider what would happen if the V were not in that term. Then for a very large surface that encloses all the charge in the system, the integral would always equal Q_{total} / \epsilon_0 (a constant) because of Gauss's Law, no matter how large the surface is. For a spherical surface of radius r, with the charge more or less at the center, the area would increase as r^2, but the electric field at the surface would decrease as 1/r^2, and the two effects would cancel out.
Now put the V inside the integral. It decreases like 1/r for very large r, so it forces the integral towards zero as r goes to infinity.
The original volume integral from which the above expression was derived is taken over all space. Therefore, the surface integral above is taken across a surface located "at" infinity. (You can think of it as a sphere whose radius approaches infinity.) Now, for all physical charge distributions, both V and E vanish as r approaches infinity. Therefore, the integrand vanishes at the surface of integration, and the integral is also zero.
To be more precise, you need to be careful about the limiting behavior of the integrand. The integration itself will contribute an r^2 term, meaning that even slowly-decaying integrands like 1/r won't decay fast enough to overcome this. Luckily, V(r) goes like 1/r and E(r) goes like 1/r^2, so the overall behavior is 1/r * 1/r^2 * r^2 = 1/r, which is still a decaying function.
I got it now.Thanks for the help!
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
