Derivation of planetary orbit equation with Lagrangian
The discussion centers on the derivation of the planetary orbit equation using Lagrangian mechanics, specifically addressing the constancy of angular momentum represented by the equation $$\dot{φ}=\frac{l}{\mu{r^2}}$$. The participants clarify that the constancy arises from the Lagrange equation, where $$\frac{\partial L}{\partial \varphi}=0$$ leads to the conclusion that $$\frac{d}{dt}\frac{\partial L}{\partial \dot\varphi}=0$$. Additionally, they explore the general solution of the differential equation $$\frac{\mathrm{d}^2 w}{\mathrm{d} \varphi^2}=-w$$, confirming that it can be expressed as $$w(\varphi)=A \cos(\varphi+\delta)$$, where $$A$$ and $$\delta$$ are constants derived from integration constants $$A_1$$ and $$A_2$$.
  • Understanding of Lagrangian mechanics and the Lagrange equations.
  • Familiarity with differential equations, particularly second-order linear equations.
  • Knowledge of trigonometric identities and their applications in physics.
  • Basic concepts of angular momentum in classical mechanics.
  • Study the derivation of Lagrangian equations in classical mechanics.
  • Learn about the properties of second-order linear differential equations.
  • Explore the relationship between angular momentum and orbital mechanics.
  • Investigate the implications of conic sections in planetary motion.
Students and professionals in physics, particularly those focusing on classical mechanics, orbital dynamics, and mathematical physics. This discussion is beneficial for anyone looking to deepen their understanding of Lagrangian mechanics and its applications in celestial mechanics.
TimeRip496
I am stuck at this part page 1,
$$\frac{\partial{L}}{\partial{\dot{φ}}}=\mu{r^2}\dot{φ}=const=l------->\dot{φ}=\frac{l}{\mu{r^2}}......(8)$$
Why is this a constant? Isn't r and dφ/dt variables of time?
Source: http://www.pha.jhu.edu/~kknizhni/Mechanics/Derivation_of_Planetary_Orbit_Equation.pdf
it is because ##\frac{\partial L}{\partial \varphi}=0## and due to the Lagrange equation: ##\frac{d}{dt}\frac{\partial L}{\partial \dot\varphi}=\frac{\partial L}{\partial \varphi}## one gets ##\frac{d}{dt}\frac{\partial L}{\partial \dot\varphi}=0##
ok Thanks a lot!
I have one more question as to how did the source get this w(φ) = Acos(φ+d)? The equation is below eqn(14) which is stated in here " which has the well known solution w(φ) = Acos(φ+d), where both A and are constants. We can always choose d= 0 by a convenient choice of φ"
The most general solution of the differential equation
is given by
$$w(\varphi)=A_1 \cos \varphi+A_2 \sin \varphi,$$
where ##A_1## and ##A_2## are constants of integration. This follows, because for a homogeneous 2nd-order linear differential equation the solution is the linear combination of two arbitrary linearly independent solutions, and cos and sin fulfill these conditions.
Now you can write this general solution also in another form,
$$w(\varphi)=A \cos(\varphi+\delta),$$
where ##A## and ##\delta## are constants. To see this just use the addition theorem for cos
$$w(\varphi)=A \cos \delta \cos \varphi - A \sin \delta \sin \varphi.$$
Comparing with the general solution above you have
$$A_1=A \cos \delta, \quad A_2=-A \sin \delta,$$
and you always find ##A>0## and ##\delta \in (-\pi,\pi]## to fulfill these equations. First we have
$$A=\sqrt{A_1^2+A_2^2}, \quad \delta =-\mathrm{sign} A_2 \arccos \left (\frac{A_1}{\sqrt{A_1^2+A_2^2}} \right).$$
So indeed the given solution is the most general one for the differential equation for ##w##.
is given by
Thanks a lot for the reply! But i am stuck at this part
Isn't $$\quad \delta=arccos(\frac{A_1}{A})=-arcsin(\frac{A_2}{A})$$?
Besides do you mean that $$w(\varphi)=A \cos(\varphi+\delta),$$ is more general than $$w(\varphi)=A_1 \cos \varphi+A_2 \sin \varphi,$$? If so, I can't see the reason behind it.
No, both equations are equivalent, as demonstrated in the previous posting. You can always map from the pair ##(A_1,A_2)## of integration constants to the pair ##(A,\delta)##. It just depends on what you consider more convenient. In this case, it's easier to see that the orbit is a conic section (ellipse, parabola, hyperbola), using the ##(A,\delta)## notation.
Oh I see. But how did you obtain this $$\quad \delta =-\mathrm{sign} A_2 \arccos \left (\frac{A_1}{\sqrt{A_1^2+A_2^2}} \right).$$?
  • · Replies 19 ·
  • · Replies 21 ·
