Derivative of a special function
The discussion revolves around the derivative of a special function defined as f(x) = ∞ for x < 0 or x > a, and f(x) = 0 for 0 < x < a. Participants explore the behavior of the derivative at the points x = 0 and x = a, noting that the derivative of a step function is represented by the Dirac delta function, δ(x). The challenge arises from the infinite jump at x = 0, leading to the conclusion that generalized functions must be employed for proper analysis. The conversation highlights that the provided "function" does not meet the criteria of a standard function, necessitating advanced mathematical concepts for a valid interpretation. Overall, the discussion emphasizes the complexities involved in differentiating functions with infinite discontinuities.
orienst
Let f(x) be the following function:
f(x)=\infty,if x<0 or x>a;f(x)=0,if 0<x<a.
What’s the derivative of f(x) at x=0 and x=a? I know that the derivative of step function is \delta(x) , but what will occur if the jump is infinite?
Mathematics news on Phys.org
f ' (x) = dx*f(x)
In general the derivative of a jump of size a at u is aδ(x-u). your a is -∞ and u=0.
JJacquelin said:
f ' (x) = dx*f(x)
Thanks for your reply.
Note that the "function" you give is not really a function. And Jjaquelin and mathman had to use "generalized functions" to give an answer.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
