Derivative of energy is force?
  • Context: Undergrad
  • Thread starter Thread starter physicsisfeyn
    Derivative Energy Force
The derivative of energy with respect to displacement yields force, as established in the discussion. Specifically, when analyzing kinetic energy (KE = 1/2 mv²), the derivative results in force (F = ma) under the assumption of constant mass. Additionally, the conversation touches on Einstein's equation E=mc², clarifying that it does not imply force converts into mass as one approaches the speed of light. Instead, it serves as a conversion factor between energy and mass.
  • Understanding of basic physics concepts such as kinetic energy and force
  • Familiarity with calculus, particularly derivatives and integrals
  • Knowledge of Einstein's mass-energy equivalence principle
  • Basic grasp of momentum and its relationship to force
  • Study the relationship between force and displacement in classical mechanics
  • Learn about the implications of relativistic physics on mass and energy
  • Explore the concept of momentum and its mathematical derivation
  • Investigate the principles of work and energy in mechanical systems
Students of physics, educators teaching mechanics, and anyone interested in the mathematical foundations of energy and force relationships.
physicsisfeyn
Why is the derivative of energy force? For example: KE=1/2mv^2 the derivative of which, assuming mass is held constant is KE'= ma. Why is this? What is the significance of this? What are some applications of this?
Additionally, Einstein's famous equation, E=mc^2, relates mass with energy. Does this mean as you approach the speed of light, that force is actually converted into mass? For example, if you have a mass of 1kg traveling with an acceleration of 299,000,000m/s and you double the force (which is 299,000,000N times 2) that some of the force is actually transformed into mass?
welcome to pf!
hi physicsisfeyn! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
nooo … derivative of momentum is force: d(mv)/dt = ma
d(1/2 mv2)/dt = mv dv/dt = mva
if you mean d(1/2 mv2)/dv, that's momentum, mv (and the meaning is that the laws of physics are invariant under a change of velocity of the observer, so differentiating the conservation of energy wrt v must still give a conservation equation, and the only one left is momentum!)
i don't see any way of getting ma from 1/2 mv2 :confused:
no, e = mc² has nothing to do with the speed of light, the c² has no physical significance: it is simply the conversion factor between J and kg
if energy was measured in light-kilograms (in the same way that distance can be measured in light-years), then the conversion factor would be unnecessary, and the formula would be e = m :wink:
Derivative of Energy or Work with respect to displacement s yields force. This is from the definition of work as integral of force over distance s and the basic theorem of calculus.
In the case of kinetic energy taking direvative wrt to s and have in mind that v=ds/dt we have dE/ds=mvdv/ds=mv(dv/dt)(dt/ds)=mavdt/ds=ma.
F = dU/dx
and F = dP / dt
Okay.
So am I wrong in thinking that mass increases with speed? If so, what happens when you approach the speed of light? If you're right at the barrier, say .9999c, and you double the force, what happens?
you can keep increasing the momentum indefinitely
the momentum is m0v/√(1 - v2/c2), which "approaches infinity" as v approaches c …
loosely speaking, doubling the momentum gets you twice as close to c :wink:
force times distance = energy
As somebody else said the derivative of energy with respect to distance is force
Keep it simple and assume the mass stays constant:
d/dx (m v^2 / 2)
= m/2 d/dx (dx/dt)^2
= m/2 dt/dx d/dt (dx/dt)^2
= m/2 dt/dx (2 dx/dt) d^2x/dt^2
= m d^2x/dt^2
= ma
For example the energy stored in a spring = 1/2 K x^2
and the force in the spring = d/dx (1/2 K x^2) = Kx
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 48 ·
  • · Replies 28 ·
  • · Replies 16 ·
  • · Replies 46 ·
  • · Replies 77 ·
