Derivatives involving the Absolute Value of Functions
The discussion revolves around finding the derivative of the function y = ln|sec(x) + tan(x)|. Participants are exploring the implications of the absolute value in the context of derivatives and are attempting to identify errors in their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the cancellation of terms involving sec(x) and tan(x) and question the validity of their simplifications. There are inquiries about handling the absolute value in the derivative and whether separate cases are needed for positive and negative scenarios.
Some participants have identified errors in their previous calculations and are seeking clarification on how to simplify their expressions. There is ongoing exploration of the relationship between the expressions in the numerator and denominator, with hints of potential simplifications being discussed.
Participants reference the use of WolframAlpha for verification of their answers, indicating a reliance on computational tools to check their work. There is also mention of the need to consider the behavior of the function in different domains due to the absolute value.
Cardinality
Problem:
Attempted Solution: See Attachment
I was hoping someone could identify my error and possibly write it out for me. At first I thought my steps were correct and everything was in order. However, when I checked my answer on WolframAlpha it gave me a slightly different result (actual answer is shown at the bottom of the attachment).
Thanks!
P.S: This was the source I consulted before attempting this:
It could be possible that there's another technique I'm not aware of to solve such questions.
You made an error when canceling ##\sec(x) + \tan(x)## in the numerator with ##((\sec(x) + \tan(x))^2)^{1/2} = |\sec(x) + \tan(x)|## in the denominator. Since ##\sec(x) + \tan(x)## is negative for some values of ##x##, the two expressions are not the same.
Also note that ##\sec(x)\tan(x) + \sec^2(x)## can be simplified.
I see my error! The numerator is now correct.
But I have two of these ((sec(x)+tan(x))2)1/2=|sec(x)+tan(x)| expressions in the denominator, and the answer has only one.
How would I go about handling this?
The answer you wrote at the bottom of the page is incorrect, and it also doesn't match what I get if I use Wolfram Alpha, so I'm not sure where you got that expression. Ignoring that answer for now, I assume you currently have:
$$\frac{(\sec x \tan x + \sec^2 x)(\sec x + \tan x)}{|\sec x + \tan x|^2}$$
Do you see how this can be simplified?
Yes I have that answer exactly! (I simplified by factoring out the secx to get (secx)((secx + tanx)^2) in the numerator)
Sorry, I realized my input into WolframAlpha was incorrect. Thanks for your help!
Here is the output that Wolfram Alpha gives:
$$\frac{\sec x(\sec x + \tan x)^2}{|\sec x + \tan x|^2}$$
But this is a case of WA being obtuse: clearly this can be reduced to a much simpler expression! Do you see why?
Not sure, but I have two guesses:
a). What catches my eye first are the (secx + tanx)^2 in the numerator and denominator. But, I don't know anyway to simplify the expression further.
b). A possible trigonometric identity I don't see?
Haha, give me a hint! :P
Is not a2=|a|2 for any a?
You overcomplicated the solution. Better to use the other definition of the absolute value: |a|=a if a≥0, |a|=-a if a<0.
ehild
Cardinality said:
Problem:
Thanks!
Recall that
[tex]\frac{d \ln|w|}{dw} = \frac{1}{w}[/tex]
holds whether ##w## is positive or negative.
ehild
So would I have two separate solutions? i.e: One for when the denominator is positive and the other for when it is negative, and then simplify from there?
Or is it something else?
Ray Vickson said:
Recall that
Thanks! I have the absolute value in the denominator so far, I guess it serves as a general answer.
If what ehild said applies and I can have two separate answers (one for when the denominator is positive and the other for when it is negative), I should be able to simplify further!
You don't have to go back and redo the problem another way unless you want to. The answer you have is fine, but you should simplify it:
Look at those two similar-looking expressions in the numerator and denominator. If ##y## is a real number, then what is the difference between ##(y)^2## and ##|y|^2##?
Sure, but that is exactly where the formula ##d \ln|w| / dw = 1/w## comes from; in other words, it has already been done, automatically.
You have to get the derivative of the logarithm of the absolute value of a function y(x).
ln(|y|)= ln(y) if y>0, and the derivative is ##\frac{d\ln(y)}{dx}= \frac{y'}{y}##
In case y<0, ln(|y|) = ln(-y), and the derivative is ##\frac{d\ln(-y)}{dx}= -\frac{y'}{-y}=\frac{y'}{y}##
The derivative is the same both for y<0 and for y>0, as Ray told you...
The function y is ##y=\sec(x)+\tan(x)=\frac{1+\sin(x)}{\cos(x)}##, and its derivative is ## y'=\frac{1+\sin(x)}{\cos^2(x)} ## so y'/y=?
It is that simple.
ehild
It is that simple.
ehild
Ahh, I see it! Thank you...makes my method seem very tedious
So y'/y = 1/cos or sec :-p
Yes, it is sec(x).
ehild:smile:
Now that you have the answer, I'll elaborate on what I said in post #11:
Note that for any real ##y##, we have ##(y)^2 = |y|^2## (the absolute values make no difference), so we can cancel the numerator and denominator to get ##\sec(x)##.
