Deriving a formula and induction
The discussion centers on deriving a formula for the recursive sequence defined by T(2)=1 and T(n+1)=1+2T(n). Participants express confusion about how to derive a new formula from the given recursive definition. One user identifies a pattern in the sequence, suggesting that T(n) can be expressed as 2^n - 1. The conversation highlights the need for clarity in transitioning from the recursive definition to a closed-form expression. Ultimately, the goal is to derive the formula and prove it through mathematical induction.
muso07
We know that T(2)=1, and T(n+1)=1+2T(n), i.e. T(3)=1+2*1=3, etc.
Derive a formula for T(n) from above information. Prove the formula by mathematical induction.
I don't think there are any apart from the stuff from above.
I don't really know where to start... Isn't T(n+1)=1+2T(n) already a formula? How am I supposed to come up with another one?
Basically, in the previous part, I showed that the sequence goes 1, 3, 7, 15, 31,.. as per the rule. (Not sure what the point of that was.) But the question says to use that to derive the formula.
I just need some help with coming up with the formula.. hopefully I can do the induction stuff by myself.
Any help would be greatly appreciated!
Hi Muso07
I noticed you could re-write the first 2 terms as:
T(2) = 1 = 1+(1-1) = 2-1= 2^1 - 1
T(3) = 1+2.1 = 2 + 2 - 1 = 2^2 - 1
hope this helps
Thank you so much!
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
