Deriving a Uniform Circular Motion Equation
The discussion focuses on deriving the equation (mV^2/r)cos(x) = mgsin(x) related to uniform circular motion. Participants suggest simplifying the equation to tan(x)g = V^2/r and emphasize the importance of understanding the forces acting on a banked curve. They recommend drawing a diagram to visualize the forces and acceleration involved in the problem. Clarifications about the context of the problem, such as whether it pertains to a banked curve, are also discussed. Overall, the conversation highlights the need for a clear understanding of the forces at play in circular motion scenarios.
ethanh
Derive the following equation: (mV^2/r)cos(x) = mgsin(x)
I don't know how you would exactly derive the equation but you can simplify it to:
tan(x)mg = mV^2 /r
You can also divide by the m and get tan(x)g = V^2/r ...
Any help is appreciated.
Hi ethanh! :smile:
hmm … doesn't look right to me … :confused:
Can you show us the whole question? :smile:
The teacher just said to derive the equation using Circular Motion Equations,Newton's 2nd Law, etc.
The equation is:
m(V^2/r)cos(θ)=mgsin(θ)
The only place where I can see you deriving this from is from a banked curve question, so think about the forces acting there.
… draw a diagram … !
Yeah … Snazzy's right (and I was being dense). :redface:
Thanks Snazzy! :smile:
It's a horizontal circle, banked like a cycle track.
ok, draw a diagram of just one bit of the track, and draw in the two forces and the acceleration (so that's three arrows … and give each one a letter, of course), and the angle.
Do you know the values of any of these forces or acceleration (without any theta)? :smile:
