Deriving Equations for Light Sphere in Collinear Motion - O and O' Observers
  • Level: Graduate
  • Thread starter Thread starter cfrogue
    Light Sphere
592 replies · 64K views
Jorrie said:
There are just two events (which you specified). In both frames the emission event is at coordinates (0,0).
In O', the reception event coordinates are given by you (geometric units, c=1)
[tex]x'=-r[/tex]
[tex]t' = r[/tex]
In O, the reception event coordinates can be found by using the LTs.
[tex] x = \gamma(x'+vt') = \gamma(-r+vr)[/tex]
[tex] t = \gamma(t' +vx') = \gamma(r-vr) [/tex]
If you use a different method, numerically, your answers must be the same as given by the LTs.
It is much easier using a Minkowski diagram! ;)
Could you calculate the time dialation?
Is there not time dilation for a rest frame and a moving frame?
So, given an elapsed time in O, what is the elapsed time in O' with relative motion v?
JesseM said:
"Proper time interval in a stationary frame" does not make sense as a phrase, "proper time" always refers to the time between events on a specific worldline as measured by a clock moving along that worldline, so it's a frame-invariant quantity. Do you mean there is a coordinate time of t in the stationary frame for an object to move from x1 to x2? In this case, in the object's own rest frame, the coordinate time between the object passing markers at these two points would be t/gamma (since the object is at rest in this frame, this would also be the unique proper time along the object's worldline between these two passing-events). I don't really see what this has to do with the example of the clock at the end of the rod though, since we weren't talking about the time for that clock to move between two positions, we were talking about the time that would be displayed on that clock when the light from the flash reached it. Do you agree that if the clock was synchronized so that it read a time of zero simultaneously with the flash in its own rest frame, then it would read a time of r/c when the light reached it?
I think I need to take this slowly.
Time dilation if O is synched at 0 is t' = λt for the moving frame O'.
Is this correct?
Is this correct?
The question is too vague. What do t' and t refer to? If they're time-intervals, you need to pick specific events you're measuring the time intervals between in each frame. For example, if we have Event 1A = the light flash, and Event 2 = the light reaching the clock, then no, your equation is not correct, in this case t would be r/(gamma*(c+v)) while t' would be r/c. On the other hand, if we have Event 1B = the event on the clock's worldline that is simultaneous with the light flash in frame O, and the same choice of Event 2, then t' = t/gamma.
OK, I am simply talking about a general Δt in O.
What is the elapsed time in O'?
In the special theory of relativity, a moving clock is found to be ticking slowly with respect to the observer's clock.
http://en.wikipedia.org/wiki/Time_dilation
Can you confirm or deny this logic?
Further, do you have the equation for this time dilation?
Sorry but this is meaningless. There is no "general Δt", in SR it only makes time to talk about a time interval between a specific pair of events.
Yes, of course I confirm it, but you have to understand what types of events it applies to. The time dilation equation says that if you have two events 1 and 2 which happen at the same position in frame A (like two readings on a clock that is at rest in that frame), and the time between these events in frame A is tA, then if you look at the time between the same pair of events in a different frame B moving at speed v relative to A, and if the time interval between them in B is tB, the two times will be related by tB = tA*gamma.
So if you want to apply the time dilation equation, you have to pick a specific pair of events which are colocated (happen at the same position coordinate) in one of the two frames, otherwise you're misusing the equation. For example, I mentioned the option of picking the following two events:
Since both these events happen along the clock's worldline, obviously they are colocated in frame O' where the clock is at rest. So, plugging in t' for tA in my above notation, we have t = gamma*t', or equivalently t' = t/gamma, which is exactly what I said would be true for this pair of events at the end of my last post.
JesseM said:
Sorry but this is meaningless. There is no "general Δt", it only makes time to talk about a time interval between a specific pair of events.
Well, since I said Δt, that means I have selected two timing events in O. That means I have a general start point and a general endpoint. How I pick these may be important later.
But, for the general equation they are not.
So, according to wiki we have,
t' = t*λ
You said t = gamma*t', why is that?
cfrogue said:
you had Δt' = γ Δt.
Therefore, when O elapses Δt, then O' elapses γ Δt.
Is this correct?
If Δx=0 then yes.
DaleSpam said:
If ?x=0 then yes.
what do you mean?
what is the time dilation equation for what I gave?
The general equation is given by the Lorentz transform
[tex]\Delta t' = \gamma ( \Delta t - \frac {v}{c^2} \Delta x )[/tex]​
The time dilation formula
[tex]\Delta t' = \gamma \Delta t[/tex]​
applies only in the special case when [itex]\Delta x = 0[/itex], which is what the Wikipedia article says: "[itex]\Delta t[/itex] is the time interval between two co-local events (i.e. happening at the same place)"
Do you mean we can no longer apply time dilation between frames?
what if I said, co-local events means events in the same frame.
cfrogue said:
I have a light timer on the left end of a rod of length r and a light source in the center of the rod. A light timer records the time when light strikes it. This will be the moving frame at v.
cfrogue said:
Could you calculate the time dilation?
The equations for your original scenario have been given a few times already, but if you want numerics, let's make the length of your rod r = 2 light seconds, so that x' = -1 light second and hence the time t' = 1 second. Let the relative speed be v = -0.6c (O relative to O'), giving gamma = 1.25.
[tex] <br /> x = \gamma(x' - vt') = 1.25 (-1 + 0.6) = -0.5<br /> [/tex]
[tex] <br /> t = \gamma(t' - vx') = 1.25 (1 - 0.6) = 0.5<br /> [/tex]
As JesseM told you before, when there are both time and space increments in one frame, you cannot simply work out 'time dilation' by applying gamma to the time coordinate alone. You have to use the LTs, where the space increment also influences the coordinate time of the other frame.
As a valuable exercise, I urge you to sketch your scenario on a Minkowski spacetime diagram. You will probably immediately understand the above result! ;-)
This is just the other way around, but the answer is also known from the above calculations.
Jorrie said:
The equations for your original scenario has been given a few times already, but if you want numerics, let's make the length of your rod r = 2 light seconds, so that x' = -1 light second and hence the time t' = 1 second. Let the relative speed be v = -0.6c (O relative to O'), giving gamma = 1.25.
Can you please tell me the restrictions to the time dilation equation?
I did not know I am not allowed to apply it given a frame and given an elapsed time in that frame vs a frame moving with collinear relative motion.
Can you explain this?
But you need a specific pair of events in order to decide the time between them in another frame. Suppose we have an event 1 that occurs at t1 in O, and another event 2 that occurs at t2 in O. Now suppose we pick a different pair of events, event 3 that also occurs at t1 in O, and event 4 that also occurs at time t2 in O. Obviously in frame O, the time interval between 1 and 2 is the same as the time interval between 3 and 4, in both cases it would be Δt=(t2 - t1). Now, do you understand that in frame O', the time between 1 and 2 may be different than the time between 3 and 4? Again, please answer yes or no.
But that's where you're wrong, the general equation can only be used when you have picked a pair of events that are colocated in one of the frames.
t' = t*λ
The equation can be written in different ways depending on which is the frame where the two events are co-located. Note that they define Δt as:
the time interval between two co-local events (i.e. happening at the same place) for an observer in some inertial frame
However, in my notation t' was the time between two events which were co-located in frame O':
So you can see that there is no inconsistency, we both agree that if tcolocated is the time between two events in the frame where they are colocated, and tnoncolocated is the time between the same events in the frame where they are not colocated, then the equation has the form:
tnoncolocated = gamma*tcolocated
I can do no better than what JesseM and DrGreg has already done. :)
In the end, my final advice is: learn the basics and learn it well. And, do learn Minkowski Spacetime diagrams...
I already said yes.
But, I have two events exclusively in one frame.
So, why can't I apply time dilation?
Do you mean the time dilation equations depends on a location?
So, if I have a time interval in O, there must be a location of the same position for two events?
The events, MUST occur at the same location in frame O or time dilation is not applicable.
Is this true?
Therefore, we must have only events at the same location in a frame or there is no time dilation period.
Please confirm or deny this.
Otherwise, you are simply talking about two events in the same frame in which case my example holds.
I sure do hope this helps me understand when I am allowed to apply time dilation.
You and I were applying time dilation in a twins thread.
In addition, there is a paper that applies the integral of time dilation.
Can you prove and explain why the paper's logic had colocated events during acceleration?
Otherwise, the logic of the paper is false.
cfrogue said:
I already said yes.
How could you? I never asked you that question before, I asked a different question about simultaneity.
Do you? What are they? Anyway, the phrase "two events exclusively in one frame" doesn't seem to make sense, events are physical things that are assigned coordinates by all frames, they don't "belong" to one frame or another.
It would also be applicable if the events occurred at the same location in frame O' (as in my example with events 1B and 2 from post 275)...the point is just that you need to pick a pair of events that occur at the same location in one of the two frames you're using, it doesn't matter which one. One way or another, the equation will then take the form tnoncolocated = gamma*tcolocated
If by "there is no time dilation period" you just mean "you can't plug the time intervals into the time dilation equation and expect it to be valid", then that's correct. You can only plug two time intervals into the time dilation equation and expect it to be valid when the following conditions are met:
1. Both time intervals represent the time between a specific pair of events, as measured in two different inertial frames
2. The two events occurred at the same spatial location in one of those frames
cfrogue said:
what do you mean?
What I mean is that the time dilation formula, Δt' = γ Δt, applies only if Δx=0 (that is what it means for two events to be co-located). Please see my derivation in https://www.physicsforums.com/showpost.php?p=2472240&postcount=266". Since Δx is not 0 in this case you need to use the full Lorentz transform equation:
[tex]\Delta t' = \gamma (\Delta t - v \Delta x /c^2)[/tex]
IMO, it is a bad idea (especially for beginners) to use the length contraction or time dilation formulas at all, they are too easy to mess up as you have seen. Instead it is best to always use the Lorentz transform, and the time dilation and length contraction formulas will automatically pop out whenever they are appropriate.
All the above is very good advice. Whether or not you use the the full spacetime view, you must use some spacetime view. The basic idea is not relativity of simultaneity, not time dilation, not Lorentz contraction.
The basic ideas begin with a conception of reality: objects move about in spacetime (worldlines of objects), and their spacetime paths intersect each other (events). For example, a photon is an object which travels in spacetime, so there is a photon worldline. The endpoint of a rod is another object which also travels in spacetime, so there is the rod endpoint worldline. The point in spacetime when the photon meets the endpoint of the rod is an event, which is where the photon and rod endpoint worldlines intersect.
Then to describe reality, we use objects such as photons and clocks to assign spatial and temporal coordinates to events. Different observers, who are themselves objects with worldlines, assign different numbers to the same underlying reality, ie. assign different coordinates to the same events.
It turns out to be an experimental fact that there are some observers who assign spacetime coordinates for the intersections of photon worldlines with their rods, such that the speed of light is c in all directions. These special observers are called inertial observers.
It turns out to be yet another experimental fact that any inertial observer A will assign spacetime coordinates for the intersection of the wordlines of any other inertial observer B with A's rods, such that the velocity of any other inertial observer B is constant.
If there is one underlying reality and the different coordinates are merely different descriptions of the same events, then we expect to have some way of relating the the different coordinates assigned by different observers to each event. The Lorentz transformations are the rule for relating the coordinate assignments by different inertial observers to an event. Time dilation is just a special case of the application of the Lorentz transformations to two events in spacetime that one particular inertial observer describes as "colocal".
Two events are co-local, relative to a frame, if the distance between the events is zero in that frame. "Events in the same frame" is meaningless, as every event occurs "in" every frame. If you meant "events that are both stationary relative to one frame", that doesn't make sense either, because an event exists only at a single instant in time, so it's meaningless to ask whether an event is moving or not.
I will think about this.
I have an additional question. If O' has a rod of rest length d, with a light source at the middle and when the light source and O are coincident the light flashes, when in the time of O will O' see the flashes as simultaneous?
I keep calculating t = d/(2*λ*(c-v)).
This is an excellent description.
If a clock in t elapses in O by t, what will elapse on the clock of O'?
I know how to derive that equation.
I know it is when Δx = 0.
Can you then use LT and tell me the time dilation for the scenerio we are talking about?
Having trouble interpreting "a clock in t elapses in O by t". Do you mean we have a clock at rest in O, and pick two events on its worldline separated by a time interval of t in O (and also separated by a proper time of t on the clock since its time matches coordinate time in O)?
Yea, I should have said from the POV of O.
We now imagine space to be measured from the stationary system K by means of the stationary measuring-rod, and also from the moving system k by means of the measuring-rod moving with it; and that we thus obtain the co-ordinates x, y, z, and , , respectively. Further, let the time t of the stationary system be determined for all points thereof at which there are clocks by means of light signals in the manner indicated in § 1;
http://www.fourmilab.ch/etexts/einstein/specrel/www/
It appears that Einstein had a "clock" located at each point of the stationary measuring-rod synchronized by SR's simultaneity convention.
Do you agree?
Yea, I am simply talking about elaspsed time in O only, no other frame.
OK, with the twins solution on Wiki and many other places, when a clock in O elapses by t, then in a moving frame, its clock in that frame will elapse λt.
http://en.wikipedia.org/wiki/Twin_paradox
