Deriving v(t) from i(t) in a Series Circuit: Finding V Across Z | Homework Help
  • Thread starter Thread starter rubber314chic
    deriving
The discussion focuses on deriving the voltage v(t) across the impedance Z in a series circuit consisting of a 0.5H inductor, a 0.01F capacitor, a second 0.5H inductor, and a 10Ω resistor, driven by the current source i(t) = 10cos(10t). The impedance Z(s) is determined to be (s + 100)/(s + 10), and the frequency-dependent impedance Z(jω) is expressed as j((ω² - 100)/ω) + 10. The correct approach to find v(t) involves using Ohm's Law in the s-domain, specifically V(s) = I(s)Z(s), and applying the Laplace transform to the current to derive I(s) before calculating the voltage.
  • Understanding of series circuits and components (inductors, capacitors, resistors)
  • Familiarity with Laplace transforms and their application in circuit analysis
  • Knowledge of impedance in the s-domain and frequency domain
  • Proficiency in applying Ohm's Law in electrical engineering contexts
  • Study Laplace transforms and their application in circuit analysis
  • Learn about calculating impedance in both s-domain and frequency domain
  • Explore the concept of inverse Laplace transforms for voltage and current calculations
  • Review Ohm's Law and its implications in AC circuit analysis
Electrical engineering students, circuit designers, and anyone involved in analyzing series circuits and AC signals will benefit from this discussion.
rubber314chic
I've been given a series circuit with a .5H inductor .01F cap, .5H inductor and 10Ω resistor in series.
This circuit is connected to a source i(t) = 10cos(10t) and I need to find v(t) across Z
From the givens I've found the Z(s) to be s+100/s+10 and Z(jω) to be j((ω^2-100)/ω)+10
I believe I need to use Ohm's law V=IR to find V. So if I multiply j((ω^2-100)/ω)+10 by 10cos(10t) I should get a v(t) but I think I'm doing something wrong with this.
what you need to do is make sure you are in the s-domain, so V(s) = I(s)Z(s), you need to perform laplace transform to the current output to obtain I(s), then you can multiply that with the frequency dependent impedance, then finally get your answer from the inverse laplace of the product
  • · Replies 26 ·
  • · Replies 35 ·
  • · Replies 16 ·
  • · Replies 16 ·
