Solve Descriptive Geometry Homework - Pt. M to N Length (-50%)
  • Thread starter Thread starter Equilibrium
    Geometry
The discussion centers on solving a descriptive geometry problem involving a line from point m(4,8,-2) heading due south with a -50% grade to find point n(?,2,?). The grade indicates a rise of -1 unit for every 2 units run, suggesting that as the line moves south, it descends. The user is attempting to plot this on orthographic paper but is struggling to determine the exact coordinates of point n. They note that the line must intersect the plane where y = 2 and is perpendicular to the y-axis, which is crucial for finding the solution. The conversation highlights the challenges of visualizing the problem in a three-dimensional context.
Equilibrium
A line from point m(4,8,-2) is due south and has a grade of -50% to pt. n. complete the location of n(?,2,?) and give the true length of the line.
Grade: \frac{rise}{run} x 100%
The plane H, F and S - if someone knows about this other than me
The bearing can only be determined in the horizontal plane (north south ETC.)
This is a graphing subject... and I am using an orthographic paper...
Lemme explain...
the point is m(4, 8, -2)... so the line downward is due south in the horizontal plane since the bearing can only be determined in the horizontal plane... but my *problem* is where is the line??
The grade here is 50% so
-50 / 100 = - 1 / 2
so 1 to the rise and 2 to the run from n thus it is going down one unit and going to the left 2 units since it is negative... but i don't know where n lies... so this is my *problem*
and I am suspecting that n lies at the y coordinate... but can't still get the point n
I don't know if i posted this on the right thread but forgive me
please help and give some hints if there's any engineer/architect having knowledge of this...
Are you using the Monge projection?
Hi radou...
No I am using the orthograpic projection w/c consists of three planes:
in the Horizontal plane or H - lies x, and y axes
Frontal plane or F - x, z
Side plane or S - y , z
See what i tried...
im using autocad w/c is similar... but for real I am really using the orthographic sheet... because this is a drafting subject
see what I plotted
so the lines from the H plane which i drew a line is due south in which i can't determine the line from south... and the other line is the line i marked which is 2 = y... in which it has the n coordinate i did this to make it easier but i can't still get it...
plus the yellow point is the point m(4, 8 ,-2)
Hint (I hope it can be found useful): the line must intersect the plane which contains the point y = 2 and is perpendicular to the y-axis.
