178 replies · 30K views
Staff Emeritus
- 37
I agree. Can you have some pictures taken while you're at the science fair demonstrating it? That would be so cool!
Shay10825
- 337
I'm using the 10 ohm 1 watt resistor and 4 batteries not 8.Ivan Seeking said:As for your choice in resistors, you had better check your calculations. You have a problem.
Do you think the aluminum foil would work?
Moonbear said:Shay, do you have a digital camera? I'd love it if you'd post a picture of your knife when it's completed! I'm sure with so many people contributing ideas to its design, they'd also enjoy seeing the final product.
Yes I'll post the picturesMath Is Hard said:I agree. Can you have some pictures taken while you're at the science fair demonstrating it? That would be so cool!
Shay10825
- 337
I bought a momentary switch. The switch has two metal loops. Should I connect the positive wire coming out of the battery holder to one loop and one end of the fuse holder to the other?
Staff Emeritus
- 2,666
Oh good I was going to ask about pictures.
As a good practice the fuse should come first in line, then the switch, but you have the idea. The switch just makes the connection to complete the circuit. The "positive current" flows from the positive terminal of the battery, through the fuse, through the switch, then through the resistor and back to the negative battery terminal.
The foil should work okay. Be careful not to create a short circuit by making contact with the resistor's bare leads. Also, make sure that you apply a good layer of heat conductive paste to the body of the resistor, and the points of contact with the blade and foil. Since you have chosen to risk over-driving the resistor you need to pull the heat away from the resistor's body as fast as possible. The foil will help to do this.
Note that 3 watts of heat is just that, 3 watts of heat. In principle it doesn't matter if we get 3 watts from 1, or from 4 resistors. Are you having trouble trying to fit more than one resistor to the blade? How are you securing the resistor?
Shay10825
- 337
would i connect it like this?
http://img47.exs.cx/img47/7294/projcombo.png
Sorry that my picture really sucks
Shay10825
- 337
This blade is driving me crazy! I cut the sheet metal and it's not turning out right. The edge of the blade I cut is jagged and it does not really look like a knife blade. I filed down the edges of it but it still has not turned out right. I don't think it really looks like a blade. The blade is not perfectly flat either. I've cut myself a million times
(not purposely). Does anyone have any suggestions on what I can do.
Shay10825
- 337
Would it look bad if the blade was shaped like this?
http://img109.exs.cx/img109/9249/blade.png
Staff Emeritus
- 2,666
The circuit looks correct. The blade looks fine to me as well.
We know how you feel. Welcome to the world of invention and design. I'll bet you never thought that engineering and science could be painful.
Staff Emeritus
- 26
Shay10825 said:This blade is driving me crazy! I cut the sheet metal and it's not turning out right. The edge of the blade I cut is jagged and it does not really look like a knife blade. I filed down the edges of it but it still has not turned out right. I don't think it really looks like a blade. The blade is not perfectly flat either. I've cut myself a million times
What did you use to cut it ? Ideally, you could cut it with a shears (if it's less than1/16"). Any machine shop/metals supplier will do that for you.
What metal are you using, and how thick is it ?
Shay10825
- 337
I cut it with shears. It is aluminum sheet metal and it's 1 mm thick.
I don't know what I'm going to do about the blade. I don't like how it looks with the foil on the back covering the resistors. If I put another piece of sheet metal what would I glue it together with. I was going to use liquid nails but it is so messy. When I put the glue on the metal the two pieces of metal did not want to stick together. It just became a big mess because the glue got all over the resistor and heat sink. So I don't want to use glue. What else could I use if I want to stick the two pieces of metal together? Could I weld it?
I also went to look for something to cover the battery holder. I wanted something like this:
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=270-1803
but I could not find anything that the battery holder I have would fit in(the one shown is way too tall). So I was just walking around Home Depot thinking about what I could do and I passed the plumbing isle. So I bought a pipe that the battery holder can fit in. I was also in the craft store today and I got some wood. Which one do you think would look better covering the battery holder? Should I use the wood and make a little box, or should I use the white plastic pipe?
Staff Emeritus
- 2,666
First, you had better not set yourself up by using an under-rated resistor and then preventing easy access for needed replacements. You need to plan for a resistor failure.
What about using a piece of copper tubing instead of a blade? This might be considered a spreading but not slicing device. Maybe you could attach a cutter to the tube?
Otherwise, I'm thinking.
Staff Emeritus
- 2,666
You could use one piece of metal and fold it over - to fit the resistor and wires but still approximate a blade. This would leave only one long side with edges. One edge could be folded around the opposite edge and sealed.
Staff Emeritus
- 2,666
You could put the resistor in a small copper tube [maybe 1/8" to 1/4" diameter] after attaching the tube to the top of the blade. You could braze or solder using lead free alloy such as silver solder.
Shay10825
- 337
Ivan Seeking said:One edge could be folded around the opposite edge and sealed.
This is a really good idea
Shay10825
- 337
Ivan Seeking said:You could put the resistorin a small copper tube [maybe 1/8" to 1/4" diameter] after attaching the tube to the top of the blade. You could braze or solder using lead free alloy such as silver solder.
I like this idea also
Staff Emeritus
- 2,666
Just make sure that you don't braze or solder with the resistor in place. Those must be inserted afterwards or they will be damaged.
On another note and as a reminder, four resistors producing 3 watts of power at a relatively low temperature produce the same amount of heat energy as one resistor producing 3 watts of power at a relative high temperature. As long as you have a good thermal bond between the resistors and the metal [by using the heat sink compound], and if in an otherwise closed system like a closed metal tube, the heat produced in the metal tube is the same. It should take a little longer to get warm since we have more resistors to heat up [also, as long as the blade isn't too massive or too large], the difference in the heating shouldn't be very great.
In this case, power is the measure of energy lost to heat in the resistor per second. So, since all of the power is going to heat, the watts of power produced is what matters, not how we produce it.
Staff Emeritus
- 2,666
You might even pound, press, or somehow crimp a large, thin wall copper tube into a blade.
Staff Emeritus
- 54
If you're not brazen enough to braze or solder, the glue/adhesives section in Home Depot ought to have some plumbing epoxy type materials. There are a bunch of these for different applications. Find one that will bond metals and is okay to get wet (though, don't get that blue marine adhesive they sell...I've tried that and it peels even when it shouldn't). The two-part epoxys usually come in a tube with two plungers that mixes them as they come out. Use in a well-ventilated area and be careful not to glue your fingers to the knife. They are usually pretty thick, so won't run all over the place out of control.
Where on the blade are you attaching the resistors? Near the top?
I think diagrams help to be sure everyone is talking about the same thing. This is a quick sketch of what I think you guys are talking about for the blade and cover for resistors, but I might be misunderstanding. See if this helps or is actually what you are all trying to accomplish.
Staff Emeritus
- 2,666
Moonbear said:Just two more day's until Shay's science fair. Good Luck Shay! Knock 'em dead! And don't forget the pictures.![]()
Hopefully, no news is good news.
Shay10825
- 337
Hi everyone
! The science fair was sooooooo much fun! The judges really liked my project. I had 8 judges for some reason (we were only suppose to have 4). I had more judges than anyone there ( I don't know if this is a good thing or not). They said the title made them wonder what it was
Guess what?
I won 1st place
You want to know why?
I was the only person in the inventions category
But it was a lot of fun. I really enjoyed it.
I'll post the pictures as soon as I get them developed.
Guess what?
I won 1st place
Staff Emeritus
- 2,666
That's great Shay! We're all very proud of you.
I can't wait for the pics.
Oh yes, IMO there is nothing better than creating your own category.
Staff Emeritus
- 37
WOOOOOHOOOO!
HOORAY FOR SHAY!
Gosh I wish there was some way to make these smilies bigger 'cause I am so happy!
HOORAY FOR SHAY!
Staff Emeritus
- 26
Congratulations Shay !
Tsu
- 62
Math Is Hard said:WOOOOOHOOOO!
HOORAY FOR SHAY!
Gosh I wish there was some way to make these smilies bigger 'cause I am so happy!![]()
My feelings, EXACTLY, MIH!
This is so wonderful, Shay! I'm so excited I can hardly sit here! We're very, VERY proud of you!
Cinnagin
- 1
i am currently taking part in a business experience thingy. generally we come up with an idea for a product and "make" it. so like a proto type and a business plan for the next year. this was an idea we had for our product but we do have limited epertise in this area as we are all 15-16 years old :S does anybody have any ideas how to make a pouch for the buttering knife, like how many ohmes for the resistor and what material for the pouch?
- PhysicoRaj
- · Replies 226 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 226
- A Furious Potato
- · Replies 3 ·
- Engineering and Comp Sci Homework Help
- Replies
- 3
- dpapavas
- · Replies 2 ·
- Chemistry
- Replies
- 2
- MikeDobbs
- · Replies 20 ·
- Thermodynamics
- Replies
- 20
- valisder
- · Replies 2 ·
- Materials and Chemical Engineering
- Replies
- 2
Undergrad
Details of the double-slit experiment?
- very_curious
- · Replies 2 ·
- Quantum Physics
- Replies
- 2
- Tabasco Sauce
- · Replies 5 ·
- Nuclear Engineering
- Replies
- 5
- hasan_researc
- · Replies 2 ·
- STEM Academic Advising
- Replies
- 2
- Sharky
- · Replies 10 ·
- Electromagnetism
- Replies
- 10
- collinsmark
- · Replies 2 ·
- Aerospace Engineering
- Replies
- 2
