Designing Your Own Transformer for Electrical Engineers
  • Thread starter Thread starter Harrison G
    Design Transformer
The discussion revolves around the design of a transformer, specifically focusing on the calculations necessary for determining the number of turns in the primary and secondary coils, as well as considerations for core material and safety. Participants share their knowledge and resources related to transformer design, including theoretical and practical aspects.
  • Homework-related
  • One participant expresses a desire to learn how to design a transformer, asking for steps to calculate the required number of turns without needing physical construction guidance.
  • Another participant emphasizes the importance of safety when working with AC mains voltages and inquires about the original poster's familiarity with transformer principles, such as turns ratio and core material.
  • A participant mentions their understanding of transformer behavior under different load conditions and the relationship between voltage and turns in coils, citing the formula V1/V2=n1/n2.
  • There is a suggestion to consider wire gauge and reluctance in the magnetic circuit, along with links to resources for further reading on transformer design.
  • Participants share links to external resources, including a transformer design handbook and educational websites, indicating the complexity of transformer design.
  • One participant advises creating a personal electromagnetic formula book to aid in understanding various transformer concepts and conditions.
  • Another participant references an old thread discussing magnetic basics, suggesting it may provide helpful vocabulary and concepts.
  • A participant outlines their intended approach to the calculations, including starting with core area and determining turns per volt, primary current, and wire gauge.
Participants generally share a common interest in transformer design and express agreement on the complexity of the topic. However, there are multiple approaches and resources suggested, indicating that no single method or consensus exists on the best way to proceed with the calculations.
Participants mention various assumptions and considerations, such as safety precautions, the importance of wire gauge, and the need to understand magnetic units and reluctance, which may not be fully resolved in the discussion.
Harrison G
Hello! I am studiyng for electrical engineer and i think its finaly time to build a transformer myself. I don't do this, cause i need one, but rather to learn how to design it. I'll be happy if you give me instructions how step by step to calculate one. Not how to physicaly build it, but to calculate the required number of turns and such.
So let's start with the fact that i have an E shape core. The frequency of the AC in my country is 50 Hz. I am thinking of powering it with 220V and the output voltage should be 110V. I don't want you to calculate it for me, i want you to tell me what steps to follow and such. Thanks! :-)
So first of all, you need to be very careful and save when working with AC Mains voltages. It is very easy to be careless and get shocked or start a fire. So we will talk about general issues first, and cover some safety considerations in a bit (since you are not about to wind it up today). :smile:
What reading have you done so far? Are you familiar with how the turns ratio of the primary and secondary windings affects the steip-up/down ratio of the transformer?
And do you know what core material is used for AC Mains power transformers?
So far on transformers i have been studiyng them in Electrical machines. I know how they behave when the secondary coil is shorted, loaded and when no load is connected to it. I mean losses and such. I know the physics behind too. I also know that there is a ratio between the Voltage or turns of the primary and voltage and turns in the secondary coils, which is given by V1/V2=n1/n2. I have been teached how to troubleshoot a transformer too. About the core material, i think it was made of steel laminations, electricaly isolated from each other in order to reduce the Eddie current and thus to minimize the heat in the core.
All correct and good! :smile:
(and don't short out the secondary for real -- that will blow the fuse that should be in series with the AC Mains input to the transformer)...
You'll need to figure out what wire gauge to use. Here's a little graphic (interactive at site) compliments of https://engineerdog.com/2015/01/05/free-electrical-wire-gauge-sizing-calculator/
Have you any familiarity with magnetic units?
You'll need to calculate the Reluctance of your magnetic circuit , including the air gap
and the Webers of flux it'll carry
and at how many Teslas you want to operate the core.
Train your search engine . Start with 'transformer design'
mine returned for starters
http://ecee.colorado.edu/copec/book/slides/Ch15slides.pdf
http://www.edn.com/design/component...sformer-at-a-frequency-it-wasn-t-designed-for
I';d wager @tim9000 could help .
Thanks all for the answers:-)
thanks @jim hardy , Yes Harrison, building a TX for yourself is a really good idea for an EE student, what year are you?
For something so simple transformers are very tricky to get one's mind around, and you'll find yourself coming up with paradoxes in your head, along the way to mastering the model.
There's a LOT of great literature on magnetic circuits and TXs so...
I suggest creating your own electromagnetic formula book, where you write down all your rules of thumb, that you need to keep reminding yourself of.
There may not be all that many formulas to remember, but there are a lot of different ways that they need to be considered, with a lot of implications and consequences that you deduce from their various incarnations. I have a healthy amount of english descriptions mixed in with the maths of mine. For instance I have various descriptions of what would happen to the various situations that the ideal model could find itself in (when the core is doing the work, when the coil is doing the work, voltage regulation, efficiency etc.) Something Jim has been a mentor for me with is understanding the dimensions in a more rich, useful, way. Like "Volt.seconds per turn as the cores flux capability", and V.s as the ability of the winding on a core to not saturate when blocking current (an inductor holds off ...volts for ...seconds) or keeping in mind the integral relationship of flux from voltage.
Don't be afraid to re-arrange the formulae, and keep the model in mind. You'll appreciate the significance of small things like resistance, that seem un-important in normal operation... understanding the various conditions like maximum inductance or saturation over permeability for various core materials and things like transients, aren't easy to hold in mind after you put the books down a couple months ago. That's why seeing it first hand on the bench is a really good idea.
P.S: Remember to use an isolation TX between you and the mains!
Thank you, guys! I will now study the links you gave me. I already have a basic idea on how to calculate it. I will start with the core area. Then i will find the turns per volt. Then the primary current(by the way do i need this current so i can figure out what gauge of wire to use?), the number of turns in the primary coil and the number of turns in the secondary coil.
Planobilly said:
Here is a good basic intro to transformers.
http://sound.westhost.com/xfmr.htm#intro0
This same site has free software used to design transformers.
Cheers,
Billy
Hey, Billy, thanks for the link. It really got me deeper into transformer science;-)
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 23 ·
