Determine a basis for kernel/nullspace
  • Thread starter Thread starter Bobman
    Basis
3 replies · 2K views
Bobman
[/B]
A=##\begin{bmatrix}
1 & 2 & 3 \\
4 & 8 & 12
\end{bmatrix}##
Question: Determine a basis for ker(A).
Ker(A)=##\begin{bmatrix}
1 & 2 & 3& |&0 \\
4 & 8 & 12& |&0
\end{bmatrix}##
(And reduce with gaussian elimination)
(Sorry for no attempt on LaTeX here, it's my first time trying to use it at all above.)
Some background information, i am revisiting linear algebra and I were doing gram-schmidt process and got a totally different answer than the textbook, however i am confident i did not make a mistake during the actual gram-schmidt.
Then it occurred to me that i must have chosen a different basis than the textbook, which made me unsure in what i recall and know about the basis for the kernel. I couldn't really find any straight forward information about it in my textbook or with a few google searches, so now I've gotten caught up in my own minor insecurities in basic details.
A easy example below to illustrate my point, are both Basis #1 and Basis #2 correct (i just realized that i wrote base on the paper...)? They would of course lead to two very different orthogonal basis when using gram-schmidt, but both would be orthogonal nonetheless.
My reasoning behind them being equally correct is that there is no (to me) intuitive "basis vector 1 and basis vector 2" as it would be for example unit vectors. Still, the span should be independent of the order in the "set" anyway if i am not wrong? I.e. i would still reach all the points regardless of the order.
A basis is an unordered set of vectors. So the two things you wrote relate to the same basis, which is indeed a basis for the null space.
Also, you don't write the s and t in writing the basis. Writing the s and t gives an arbitrary element of the null space, not a basis. In this case a basis is just two purely numeric vectors.
Great, thanks.
That's very true, i think i tried to make it overly clear with the "order" by keeping the parameters.
Thanks for clarifying!
Bobman said:
Great, thanks.
The basis vectors are the things that completely define this subspace. Every vector in the nullspace is a linear combination of these two vectors, so if ##\vec v \in Null(A)##, then ##\vec v = s<-2, 1, 0> + t<-3, 0, 1>##.
That's where the parameters come in, not when you are just listing the vectors that form a basis. Note that any nonzero multiple of either vector would also consitute a basis.
In a set, the order of the set elements doesn't matter.
