Determine period for off center disk
The discussion focuses on determining the period of a horizontally suspended disk with a rod bored through it at a distance from the center. The moment of inertia is calculated using the formula I = 1/2 ma^2 + md^2. A participant suggests using the relationship between angular acceleration (alpha), torque (T), and moment of inertia (I) to derive the period. They propose that the period can be approximated as π√((a^2 + d^2)/g*d). Confirmation of this expression is requested from others in the discussion.
boardaddict
A disk of mass m and radius a is suspended horizontally by a rod bored through the disk at a location d distance from the center. When in equilibrium the center of the disk is directly below the rod. Obtain an approximate expression for the period, ignore disapative effects
per Newtonian
I = 1/2 mr^2 + md^2
I*theta: = -mg(rsin(theta))
1/2 ma^2 +md^2
Im missing something simple here...If someone could point me in the right direction it would be appreciated
per Newtonian
I = 1/2 mr^2 + md^2
1/2 ma^2 +md^2
Wait, can I use alpha= to T/I , then relate that to 2pi to find period?
If I did this right I get ;
pi((a^2)+d^2)/g*d
If someone would confirm that would be great
