Determine the convergence of the sequence e^(1/n).
lilypetals
Determine whether the sequence converges or diverges. If it converges, find the limit.
an = e1/n
The limit laws, adapted for sequences.
I have the solution; I was just wondering if someone might explain it to me.
I would have initially guessed that the limit of this sequence is 0. Not being sure how to proceed, however, I plugged it into WolframAlpha to see the steps for this particular problem.
limn-infinity e1/n
Using the continuity of e1/n at n=infinity, write limn-infinity e1/n as elimn-infinity1/n;
The limit of a quotient is the quotient of the limits:
e1/limn-infinityn
The limit of n as n approaches infinity is infinity:
=1.
Now, that makes sense, if I consider that 1/n goes to 0 as n goes to infinity, and thus the power of e would be 0, making the limit equal to one. But I'm not clear on exactly how we got there.
First question: what does "using the continuity of e1/n at n=infinity mean?
Second question: If limn-infinity of n is infinity, why does 1/n become 0?
What does 1/n approach as you increase n?
0, right?
Yes. So when we take \lim_{n \to \infty} \frac{1}{n}, we get \frac{1}{\infty}, which is zero.
Remember that for a series to converge the nth term necessarily must go to zero. (The converse is not true in general - a series whose nth term goes to zero does not necessarily converge.)
Looking at the the nth term of e1/n as n goes to infinity, you see it is equal to 1, which means this series diverges.
From the original post, we are dealing with a sequence. So, as long as there exists a limit, the sequence converges to that limit. For a series, you are correct.
Okay, I think I get it. Does this translate to other situations as well? Dividing/multiplying by infinity causes the quotient or the product to become 0?
Doh! Misread the title.
Multiplying by infinity yields infinity. Dividing by infinity yield zero. (Technically speaking, this is an abuse of notation...)
Then we have indeterminate forms:
\frac{\infty}{\infty}, \frac{0}{0}, 0 \cdot \infty, 1^{\infty}, 0^0, \infty^0, \infty-\infty
- No. The right way to look at it is to say that 1/n gets arbitrarily small as n increases. Dividing by infinity actually makes no sense. It is a heuristic.
- If you agree that 1/n converges to 0 then its exponential must converge to 1 because the exponential function is continuous.
