Determine the phenotypes of progrency
  • Thread starter Thread starter jena
In the discussion on determining poultry comb phenotypes, participants clarify the genetic combinations resulting from the cross R/R P/p x r/r P/p. The dominant alleles for rose (R) and pea (P) combs produce a walnut comb when combined, while the recessive alleles yield a single comb. The correct approach involves creating a Punnett square to visualize the offspring's phenotypes. The expected phenotypic ratio from this dihybrid cross is debated, with options presented for potential outcomes. Ultimately, understanding the gametes from each parent is crucial for accurate phenotype determination.
jena
Hi,
My Question:
In poultry, the dominant alleles for a rose comb (R) and a pea comb (P), if present together, give a walnut comb. The recessive alleles of each gene, when present together in a homozygous state, give a single comb. What will be the comb characters of the offspring of the following cross?
a. R/RP/p´r/rP/p
I'm not sure what to do. Am I supposed to develop a combination of crosses and then put them in a punnett square to help determine the phenotypes:confused:
Thank You :smile:
It is basicly a 16 square punnett square of the cross given in a. and you have to give the character of the offsprings.
To get you started, the possible combination of one of the parent is as follow:
RP Rp RP Rp
So have to determine the combination of the other parent and then mix both parental combination.
jena said:
So you mean like this
Not quite. Go back to that very first problem set you posted here where we went through how to set up a Punnett Square for two traits and refresh your memory of how to set those up. It's the same thing here. iansmith got you started for one parent.
Hi,
So it would be a 9:3:3:1 type combination?
If so wouldn't it be the same answer for the different type of combinations for this cross
  • r/rP/P´R/rP/p
jena said:
Hi,
  • r/rP/P´R/rP/p
9:3:3:1 is the ratio you get with a dihybrid cross (when both parents are heterozygous for both traits). What are your gametes for each parent?
Hi . Help me ? which one correct .
In poultry, the dominant alleles for rose comb (R) and pea comb (P), if present together, give a walnut comb. The recessive alleles of each gene, when present together in a homozygous state, give a single comb. What will be the comb characters of the offspring of the following cross: R/R P/p x r/r P/p?
A. 1/4 walnut (R/r P/-) : 3/4 rose (R/r p/p)
B. 3/4 walnut (R/r P/-) : 1/4 rose (R/r p/p)
C. 1/2 walnut (R/r P/-) : 1/2 pea (r/r P/-)
D. 1/4 walnut (R/r P/-) : 1/4 rose (R/r p/p) : 1/4 pea (r/r P/-) : 1/4 single (r/r p/p)
E. 1/2 pea (r/r P/-) : 1/2 single (r/r p/p)
Thank You very much
