Determine the remainders when dividing their squares by four
  • Thread starter Thread starter ND3G
    Squares
The discussion focuses on determining the remainders when the squares of odd integers are divided by four. It is established that the square of any odd integer, when divided by four, consistently yields a remainder of 1. Participants explore the mathematical proof by expressing odd integers in the form of 2n + 1 and analyzing their squares. The conversation highlights the importance of correctly interpreting the remainder, emphasizing that it is 1, not 1/4. The conclusion reinforces the conjecture that the square of an odd integer always results in an even integer with a remainder of 1 when divided by four.
ND3G
Randomly select eight odd integers of less than 1000
a) Determine the remainders when dividing their squares by four, and tabualte your results
b) Make a conjecture about your findings
c) test your conjecture with at least five larger integers
d) Prove of justify the conjecture you make.
n tn = n^2 / 4 - 1, Remainder
49 600 1
81 1640 1
121 3660 1
225 12656 1
441 48620 1
625 97656 1
841 176820 1
2001 1001000 1
3673 3372732 1
6925 11988906 1
8123 16495782 1
9999 249950000 1
b) When the square of an odd integer, for n is equal to or greater than 1, is divided by four the result is an even integer with a remainder of 1.
c)
You know that tn = n^2 / 4 - 1, by hypothesis
Factoring n, tn = (n x n)/4 -1
I'm not quite sure where to take my proof from here. Could someone give me a nudge in the right direction?
These are odd integers! Any odd integer can be written in the form
2n+ 1. What is the square of that? what do you get when you divide by 4?
EDIT:
(2n+1)^2 / 4 = n^2 +n + 1/4 = n(n +1) + 1/4
The remainder is 1/4
(2n + 1)^2 is not 4n^2 + 1.
And I think he was more concerned with the remainder you get when you divide by 4, not the expression in terms of fractions.
Proof
An odd integer is a multiple of 2, plus 1. Let 2n + 1 represent an odd integer.
The square of an odd integer is 4n^2 + 4n +1 which when divided by 4 becomes n^2 + n +1/4.
Factoring n, tn = n(n+1) + 1/4
An odd number multiplied by itself will result in another odd number. adding two odd numbers will result in an even number.
Therefore, for odd integers, n(n +1) + 1/4 is an even number with a remainder of 1/4
No, the remainder is NOT 1/4!
Remember what you said initially:
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
