Which is larger: 2^500 or 5^200?
  • Thread starter Thread starter Icelove
To determine which is larger between 2^500 and 5^200, the discussion explores rewriting the expressions for comparison. The transformation to 4^250 versus 5^200 suggests that 4^250 appears larger, but further mathematical justification is needed. Participants suggest dividing the two numbers to find a common base for clearer comparison. A proposed method involves manipulating the expressions to prove that the numerator exceeds the denominator. Ultimately, a rigorous mathematical approach is necessary to conclusively determine the larger value.
Icelove
Which is bigger 2^500 or 5^200
Well I got to 2^2^250 -> 4^250 vs 5^200... by the looking at it 4^250 is bigger but I can't just say it looks bigger... There are lots of these that I can't get on a common base, so if anyone can point me to the right direction I'll give lots of love.
divide the two numbers.
come to a form of (a/b^n)^k * a^k = (a*(a/b^n))^k
prove that a/b^n > 1/a
from that you can easily proove that the numerator is bigger than the denominator
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
