Determining if a function is odd or even
  • Thread starter Thread starter ainster31
    even Function
To determine if a function is odd or even, one must evaluate f(-x) and compare it to f(x). The function given is piecewise defined, with two cases for different intervals. It is confirmed that substituting -x into the function's definition requires adjusting the inequalities accordingly. The conclusion drawn is that since f(-x) equals f(x) for all relevant intervals, the function is indeed even. Understanding the correct substitution and applying the definition of an even function is crucial for the solution.
ainster31
$$f(-x)=\begin{cases} -x+5,\quad -2<x<0 \\ x+5,\quad 0≤x<2 \end{cases}\\ =f(x)$$
The issue is that I can't get to the second step. I know the function is even.
You should have
$$f(-x)=\begin{cases} -x+5,\quad -2<-x<0 \\ x+5,\quad 0≤-x<2 \end{cases}$$
(You need to substitute -x for x in the inequalities as well.)
I have no idea what you mean by "the second step". (What was the first step?) Just use the definition of "even function".
If -2< x< 0 then 0< x< 2 so f(-x)= (-x)+ 5= -x+ 5= f(x).
If 0< x< 2 then -2< x< 0 so f(-x)= -(-x)+ 5= x+ 5= f(x).
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
