Determining pressure in the pot.
  • Thread starter Thread starter Micko
    Pressure
Heating a closed pot half full of water will initially raise the temperature until it reaches boiling point, where it will remain until all water vaporizes. As water boils, the creation of steam increases pressure, despite the volume of water decreasing slightly. Once all water has turned to vapor, further heating leads to an increase in temperature and pressure due to the fixed volume of the pot. The pressure inside the pot will start to rise as soon as boiling begins, as vapor is produced even before all water has evaporated. The ideal gas law can be used to approximate the behavior of water vapor in this scenario.
Micko
I'm trying to figure out if and how pressure in the closed pot, half full of water is going to change if pot is placed on the cooker and continuously heated.
p*V=R*T for ideal gas
I think the following will occur:
First there would be an increase in water temperature until boiling point 100C (I'm assuming outside pressure is 1 atm). After water starts boiling temperature will not change until all water vaporize. Also during heating water will slightly exapand, but pressure inside the closed pot will reamain the same.
Now, after all water is turned to vapor, further heating will cause temperature to start rising (superheated vapor). Vapor will expand and pressure is still the same. But since pot is closed further adding of heat will cause pressure inside the pot to start rising (pot's volume is constant)?
Am I right here?
Can you explain me at which point pressure inside the pot will start rising?
Thank you in advanced
The pressure will rise continually.
As the water boils more gas is created, the volume of the water goes down slightly, but the extra gas will create more pressure. As the water is boiling the temperature of the stream won't increase very much because most of the energy is going into the water.
Once all the water is boiled then it becomes a gas law problem the volume is fixed, so if you keep heating the steam pressure wil rise.
If you need a more detailed answer you will have to look at steam tables for the vapour pressure at each point.
Thanks, but want to be sure about one thing, and that is about point where pressure will start to increase. I think that pressure will start rising only after water starts boiling. Am I right there?
Is it OK to look at equation of ideal gas, because water vapor can be approximated by ideal gas in some cases?
P1V1/T1=P2V2/T2
Volume is constant so P1/T1=P2/T2
Even before it boils there will be vapour produced.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
