Determining the Efficiency of a Fuel
  • Thread starter Thread starter madoxx
    Efficiency Fuel
To determine the efficiency of fuels like gasoline, diesel, methanol, and ethanol for powering vehicles, it's essential to focus on energy per kilogram and emissions produced. Fuels themselves do not have inherent efficiencies; rather, efficiency is derived from the engine or machine utilizing the fuel. Factors such as combustion temperature significantly impact emissions, with variations in engine design affecting the output. The lower heating value of each fuel provides a measure of energy content, which is crucial for comparison. Ultimately, understanding the relationship between fuel properties and engine performance is key to assessing efficiency.
madoxx
Hi,
I'm trying to calculate the efficiency of fuels such as gasoline, diesel, methanol, and ethanol.
I have collected several properties such as energy content per gallon (btu) and densities for each fuel.
I'm a bit confused as to how i can calulate these fuels' efficiencies. Traditionally, i was taught Efficiency=actual/theoretical * 100%
How can i approach this problem??
Fuels, alone, don't have efficiencies. If you burn something, 100% of the energy of the reaction is available to you to do something with* - it's what you do with it that has an efficiency. So what are you really looking for here - efficiency of thermodynamic cycles? Cost efficiency? Energy per unit mass?
*Caveat - depending on how you burn it (how much oxygen and other gases, pressure, etc.), you may get more or less than the optimal energy from the reaction.
Sorry i was not clear... I am comparing fuels to power cars/trucks. I want to determine which fuel is the most efficient at powering these vehicles. I guess i am looking for:
-which fuel will provide the most energy per kilogram
-produce the least harmful emissions
Again, like Russ already stated, fuels do not have an associated efficiency by themselves. The efficiency measure comes from the engine/machine that is using the fuel.
Emissions are also heavily dependant upon the process that is using the fuel. For example, two cars can have the same fuel, but because one of the cars has a higher combustion temperature, it will, most likely, put put more NOx.
Fuels will have parameters that you are interested in. For example, the energy per unit mass is stated in the fuel's lower heating value. It will be in units of BTU/lbm or MJ/kg. A quick look here: http://www.chevron.com/products/prodserv/fuels/bulletin/motorgas/img/500/fig_1-6.gif shows that there is an apparent correlation in fleet activities between a fuel's heating value and fuel efficiency. The rest of the article is here: http://www.chevron.com/products/prodserv/fuels/bulletin/motorgas/1_driving-performance/pg4.asp
You might also want to take a look here: http://www.f6rider.com/Valk2/every_thing_you_ever_wanted_to_k.htm
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
