Determining the form of the real solution set?
  • Thread starter diredragon
  • Tags
    Form Set
In summary, the inequalities give the range for the solutions for x^2 + 2x+1 - 1 for real numbers a, b, c where -\infty < a < b < c. Without eliminating the values which would cause a division by zero, the student found that the solutions are of the form (a, -3, c) for (-\infty, a), (a, -1, c), (a, 0, c), where (x, y) is the point at which the numerator and denominator equal 0.
diredragon
323
##\frac{log_{2^{x^2+2x+1}-1}(log_{2x^2 + 2x + 3}(x^2 - 2x)}{log_{2^{x^2+2x+1}-1}(x^2 + 6x + 10)} \geqslant 0 ##
The set of all real solutions to this inequality is of the form:
##(a) ## ##(a,b) \cup (b,c) ##, ##(b) ## ##(-\infty,a) \cup (c,\infty) ##, ##(c) ## ##(a,b) ##
for some real numbers ##a,b,c ## such that ##-\infty<a<b<c<+\infty ##
First i found the points at which the numerator and the denominator equal ##0 ##. I found that from the following:
##log_{2^{x^2+2x+1}-1}(log_{2x^2 + 2x + 3}(x^2 - 2x) = 0 ##
##log_{2x^2 + 2x + 3}(x^2 - 2x) = 1 ##
##2x^2 + 2x + 3 = x^2 - 2x ##
from this quadratic equation i find that the zeros of the function are ##x_1=-3 ## and ##x_2=-1 ## and let them be ##a=-1 ## and ##b=-3 ## for now. i also found from the plot of the given quadratic equation that ##(-\infty,-3)\cup(-1,\infty) ## makes function a positiv one and the values in between ##(-3,-1) ## make it negative. I used that later for the rational number chart.
Similarly ##log_{2^{x^2+2x+1}-1}(x^2 + 6x + 10) = 0 ##
##x^2 + 6x + 10 = 1 ##
##x = -3 ##. This function is positive for every other value.
Now using the chart of rational numbers, determining when the whole ratio is positive and when is negative i get the positive values to range from
##(-\infty,-3) \cup (-1,\infty)## which then makes my answer of the form ##(-\infty,b) \cup (a, +\infty)##.
First of all, its not given, second, its wrong. The solution is i know the ##(a) ## answer. I just don't know how to get to it. Could you help?
It looks like you have done well to eliminate the values which would drive a division by zero. However, there are other considerations you must apply to satisfy the domain for the logarithms.
First, your base may not be zero. ##\log_0## does not make any sense.
Second, if your base is positive, your input value may not be negative, ## \forall a,b>0 \log_a (-b) ## does not exist.
However, I don't think that either of these is the cause of your trouble.
I would recommend rewriting this using some log rules.
Edit: incorrect.
Remove the outer log by putting both sides of the inequality in the exponent.
Edit: incorrect.
Then take another look.
3. The Attempt at a Solution [/B]
Please don't overly decorate your text with various font and BBCode tags if you're not sure of what you're doing. In particular, don't mix BBCode bold tags ( [B] ) with LaTeX -- it screws up both.
##log_{2^{x^2 +2x+1} - 1 } ( log_{2x^2+2x+3} (x^2 - 2x ) - ( x^2 +6x + 10) ) \geq 0 ##
Remove the outer log by putting both sides of the inequality in the exponent of ##(2^{x^2+2x+1} - 1)^y ##
So ##(2^{x^2 + 2x + 1} - 1)^y = log_{2x^2 +2x +3 }(x^2 - 2x) - (x^2 + 6x + 10) ##
That's not correct.
##\displaystyle \frac{log_{\,b}(A)}{log_{\,b}(C)}\neq log_{\,b}(A)-log_{\,b}(C)\ ##
However, the change of base formula may come in handy.
SammyS said:
That's not correct.
##\frac{log_{2^{x^2+2x+1}-1}(log_{2x^2 + 2x + 3}(x^2 - 2x)}{log_{2^{x^2+2x+1}-1}(x^2 + 6x + 10)} ##
This was rewritten correctly i think
##log_{2^{x^2+2x+1}-1}((log_{2x^2 + 2x + 3}(x^2 - 2x) - (x^2 + 6x + 10)) ##
edit: incorrect.
RUber said:
Putting both sides of the inequality into the exponent should give you something like:
##log_{2x^2 +2x +3 }(x^2 - 2x) - (x^2 + 6x + 10) \geq (2^{x^2 + 2x + 1} - 1)^0.##
Yes. It's worse than I thought. -- that is if you consider one incorrect form to be worse than another.
What RUber seems to be saying in post #2 is that ##\displaystyle \ \frac{\log_{\,b}(A)}{\log_{\,b}(C)}= \log_{\,b}(A-C)\ ##, which is absolutely wrong.
Added in Edit:
What is the case, is that ##\displaystyle \ \log_{\,b}\left(\frac{A}{C}\right)= \log_{\,b}(A)-\log_{\,b}(C)\ ##.
Also true is, ##\displaystyle \ \frac{\log_{\,b}(A)}{\log_{\,b}(C)}= \log_{\,C}(A)\ ##
Wow-- thanks SammyS. I clearly was not paying attention.
So then using the change of base to remove the quotient, and then exponentiating to remove the logs would be one way to resolve this.
The other way would be to compare signs of the top and bottom -- but I think that simplifying would help.
RUber, you're right. Considerable simplification can be done. Also, as you point out, attention must be paid to several details.
The "outer' logarithm in numerator has the same base as the logarithm in the denominator, so a change of base is in order. That leaves us with the log of a log to compare with zero.
As you point out, the base of any of these logarithms must be positive and must not equal 1 . That does eliminate at least one x value and may give OP his value for b, the deleted point.
So you suggest rewritting to ##\log_{x^2 + 6x + 10} ( \log_{2x^2 + 2x + 3} (x^2 - 2x) ) \ge 0##
That's right. And solve that like you did for the polynomial in your first post. Pay attention to the inequality. Finally, check for any values that must be excluded from the original form of the problem.
i went on like this ##\log_{x^2 + 6x + 10} ( \log_{2x^2 + 2x + 3} (x^2 - 2x) ) \ge 0##, ##\log_{2x^2 + 2x + 3} (x^2 - 2x) \ge 1##, ##2x^2 + 2x + 3 \ge x^2 - 2x##, ##x_1 = -3, x_2 = -1##, also from the change of base formula it is necessary that ##x^2 + 6x + 10 \neq 1## giving same results and that ##2^{x^2 +2x + 1} - 1 \neq 1 ## giving ##x_3=0, x_4=-2##
what to do with these results?
What does ## \displaystyle \ 2^{x^2 +2x + 1} - 1 = 1\ ## imply regarding your initial expression (prior to doing the charge of base)?
it implies ##\log_{2x^2 + 2x + 3} (x^2 - 2x) = x^2 + 6x + 10 = 1## the base is 1, so it must be 1.
But log1 is not defined as a function.
Was the appropriate range for the inequality ##(x_1, x_2)## or ##( -\infty , x_1)\cup ( x_2, \infty)##?
Depending on which interval you choose, only one of ##x_3, x_4## would be excluded from the solution set.
Edit
It looks like you have the wrong inequality...
##\log_{2x^2 + 2x + 3} (x^2 - 2x) \ge 1##, and ##2x^2 + 2x + 3 \ge x^2 - 2x## are not consistent.
To remove the log, you are doing:
##(2x^2 + 2x + 3)^{\log_{2x^2 + 2x + 3} (x^2 - 2x)} \ge (2x^2 + 2x + 3)^1##
Which should give you:
##x^2 - 2x \ge 2x^2 + 2x + 3##.
This will give you the appropriate interval for the solution once you remove your excluded point.
Edit
you are right, i have made a wrong inequality. so ##x^2 - 2x \ge 2x^2 + 2x + 3## giving me ##x_1 = -1, x_2=-3##. now since i get from the change of base formula that ##x^2 - 2x > 1## and i have what i have written above can i put the x-es i get to see which is excluded? i get by those means the ##-1, -2, -3## fit while ##0## should be excluded. I don't know if you can do it this way
then it implies that the initial inequality involves undefined functions...what else could it be
I am not sure I understand what you mean.
From the inequality ##x^2 - 2x \ge 2x^2 + 2x + 3##, you should get an interval which satisfies the condition, not just two x values.
From the condition that the base of a log cannot be 1 or 0, you get single excluded values (x1,x2,x3,x4), which you have found to be -3, -2, -1, 0. Two of those are the endpoints of your interval, and one of the other two is included in that interval.
Likes diredragon
Right!
It's undefined for what ever value of x makes ##\displaystyle \ 2^{x^2 +2x + 1} - 1 = 1\,,\ ## because then you have an expression with log1 in it.
You really should look carefully at the possible values for the base of each of your logarithms, looking for any possibly problem values.
Ok, so ##0## makes it undefined. Other vakues are ok i guess. So i would pick ##(a,b) \cup (b,c)## it has three values so only because of that i would choose it.
diredragon said:
Ok, so ##0## makes it undefined. Other values are ok i guess. So i would pick ##(a,b) \cup (b,c)## it has three values so only because of that i would choose it.
Yes, ## \displaystyle \ 2^{x^2 +2x + 1} - 1\ ## evaluated at x = 0 is 1, if that's what you mean. However, x = 0 should not be part of your potential solution set anyway (that is if you are following RUber).
Is there any other way to get 21 - 1 , or worse yet, 20 - 1 ?So, what are your values for a, b, and c, and are you sure that there are no other issues there?
Likes diredragon
I redid the problem again and i think i undestand it now. The solution is ##(-3, -2) \cup (-2, -1) ## with a gap in ##-2 ## because the base there is ##1 ##.
The expression ##x^2 - 2x \ge 2x^2 + 2x + 3 ## holds for numbers between ## -3, -1 ## any subtleties i might have missed?
Likes RUber
That appears to be the correct answer.
Are there any other subtleties?
Well, none that change the final answer, but there are some additional items to consider.
Some details:
##\displaystyle \ x^2 - 2x \ge 2x^2 + 2x + 3 \ ## holds for x in the interval ##\ \left[ -3,\, -1 \right] \ ##.
We've covered the reason for deleting ##-2## from that interval. Why are the end points also deleted?.
Well, previously mentioned is that ##\displaystyle \ 2^{x^2 +2x + 1} - 1 ## evaluates to 0 at ##\ x=-1\ ## and to 1 at ##\ x=-2,\,0\ ##.
What's up with ##\ -3\ ##? Look at ##\ x^2+6x+10 \ ##..While you're at it, consider any problems associated with ##\ 2x^2 + 2x + 3 \ ## as the base for a logarithm.
Likes diredragon
1. What is the real solution set?
The real solution set refers to the set of all possible values that satisfy a given equation or system of equations in the real number system. In other words, it is the set of values that make the equation true when substituted into it.
2. How do you determine the form of the real solution set?
To determine the form of the real solution set, you must first set the equation or system of equations equal to zero. Then, you can use algebraic methods such as factoring, the quadratic formula, or completing the square to solve for the values of the variable. The form of the real solution set will depend on the type of equation or system of equations.
3. What is the difference between a single solution and multiple solutions in a real solution set?
A single solution in a real solution set means that there is only one value of the variable that satisfies the equation or system of equations. This is also known as a unique solution. Multiple solutions, on the other hand, means that there is more than one value of the variable that satisfies the equation or system of equations.
4. Can a real solution set have no solutions?
Yes, a real solution set can have no solutions. This means that there is no value of the variable that satisfies the equation or system of equations. In other words, the equations are not consistent and have no common solution.
5. How do you graphically represent a real solution set?
A real solution set can be represented graphically by plotting the equation or system of equations on a coordinate plane. The points where the graph intersects the x-axis represent the solutions to the equation or system of equations. If there are multiple solutions, there will be multiple points of intersection. If there are no solutions, the graph will not intersect the x-axis at all.
