Determining the required properties of a submersion cooler system
A suitable radiator for a submersion cooling system for Antminer S9 units requires careful consideration of thermal conductivity and electrical insulation properties of the cooling liquid, specifically mineral oil. The design involves a steel pipe housing approximately 3.5 gallons of mineral oil, which must dissipate around 3.5 kW of heat. Key calculations include determining the temperature of the oil exiting the cooling system and the flow rate of the oil, as well as the maximum air temperature entering the radiator. An all-aluminum radiator with forced ventilation and a circulating pump is recommended for effective cooling. The design process is iterative, and radiator catalogs can provide valuable specifications for selection.
orris
TL;DR
I require assistance in selecting a suitable radiator for a submersion cooing system
Summary: I require assistance in selecting a suitable radiator for a submersion cooing system
Hello,
I am designing a series of chassis's and cooling rigs that will house ant miner s-9 units along side their apw3 power supplies flooded with mineral oil within the housing.
Each unit will consist of a steel pipe 28'' in length with an I.D of 6 in \ approx 6.35 in reality \yielding roughly 792/in^3 for aprox 3.5gal of mineral oil
witch has a specific heat of 1.67kj/kgK not much different than air but i need to use a liquid that is thermally conductive but not electrically conductive as the units will be submerged. Between the mining unit and the powersupply each rig need to dissipate roughly 3.5kw
I am having a very interesting time trying to find a formula to size my radiator selection .
The radiator should be an all aluminum affair with fan on one side providing forced ventilation,Aswell as a small pump to keep the oil continuously circulating.
Any assistance would be appreciated
You need to find the following:
Temperature of oil on the hot side where it comes out of what you are cooling.
One of the following (note that you calculate one from the other):
Temperature of oil leaving the cooler
OR
Flow rate of oil
What is the maximum temperature of the air into the radiator?
The leaving temperature of the air is calculated from the air flow rate, or vice versa.
With all of the above information, you are ready to start studying radiator catalogs.
Here is one source of radiators: http://www.willowsra.com/new_cuts/Water%20Coils/WSD_Coils.pdf. They are not exactly what you are looking for, but will give you some idea of what information is available. You would need to interpolate for your temperatures, and adjust for oil instead of water. I have one of their 18X20 coils heating my shop, and their specifications seem to be accurate.
Have fun, because the design process is iterative.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
