Development of a thermodynamic property database hydrocarbons
The discussion centers on the development of a thermodynamic property database for hydrocarbon fuels, with an emphasis on understanding Maxwell relationships and the Clapeyron equation. The project aims to predict properties such as specific heats and phase behavior. The initiator seeks advice on essential database features and reliable sources for isooctane data. Several existing resources and databases are suggested to aid in gathering necessary information. Overall, the conversation highlights the importance of leveraging available data for effective database development.
johnsmith456
Hiya guys,
I've just started a project, of which the aim is to develop a thermodynamic property database for hydrcarbon fuels.
I've been asked to start by reading up on the maxwell relationships and clapeyron equation etc. so hopefully this will give you an idea of what I am trying to develop.
I don't have a specific question because I am at a bit of a loss on this one at the moment.
Does anyone have any salient advice for what the database should be able to predict, specific heats, phase etc..
Also I have been asked to find some properties/data on isooctane, does anybody know of a good source where I can find some info on this?
Any advice would be a huge help, thanks in advance.
Regards
John
Science news on Phys.org
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
