Diameter of circle of light seen from above water - illuminated beneath
The diameter of the circle of light illuminated on the surface of a liquid with a refractive index of 1.50, where a small light source is positioned 22.0 cm below the surface, is calculated to be 54 cm. This is derived using Snell's Law and trigonometric relationships, specifically the critical angle of 41.8° and the tangent function. The calculation involves determining the radius of the circle using the formula tan(θ) = r/h, where h is the depth of the light source. The resulting diameter is then obtained by doubling the radius.
  • Understanding of Snell's Law and its application in optics
  • Knowledge of trigonometric functions, particularly tangent
  • Familiarity with the concept of critical angle in refraction
  • Basic geometry related to circles and angles
  • Study the derivation and application of Snell's Law in various media
  • Learn about total internal reflection and its implications in optics
  • Explore trigonometric identities and their use in solving geometric problems
  • Investigate the properties of light sources and their behavior in different refractive indices
Students studying physics, particularly those focusing on optics, as well as educators and anyone interested in understanding the principles of light behavior in different media.
Marcargo
A small light is 22.0 cm below the surface of a liquid of refractive index 1.50. Viewed from above, the light appears to illuminate a circle on the surface of the water. What is the diameter of the circle?
cm
Snell's Law
n1sin(θ)1 = n2sin(θ)2
Based on Snell's law:
1.6 x 1 = 1 x sinθ, if I can find the angle of refraction, then maybe I can find the diameter of the circle with trigonometry?
I can't really see a way through this one - I'm thinking that I want to find the 'radius' of the circle, and from there, find the diameter. Maybe the distance that the light is used below the circle can be then used as a side for trigonometry to find the radius?
cm
Snell's Law
The problem is not quite complete. They did not specify the geometry of the light source. However, the usual simplifying assumption is that of a point source of monochromatic light that emits isotropically (i.e. same intensity in all directions).
What you should be thinking of is the phenomenon of total internal reflection when the angle of incidence exceeds the critical angle. Think about this: light rays emerge at all angles from the light source. Does every ray that hits the surface actually escape into the air? Can you construct a "limiting cone" for the light that actually escapes the water?
Welcome to PF!
Hi Marcargo! Welcome to PF! :smile:
(what's 1.6? :confused:)
yes, you've used θ1 = 90°, so that gives you θ2 :smile:
so you have a right-angled triangle, and you know the angle and one side …
where's the difficulty? :wink:
The difficulty is that "1.6 x 1 = 1 x sinθ" produces sin(θ)=1.6 . :biggrin:
ehild
Ok, so I've worked out the critical angle for the light - sin-1(n2/n1)
= 41.8°
This gives me the angle, and from trig, I used tan θ = r/30
= 26.8cm
diameter = 26.8 x 2 = 54cm (2sf)
Thank you for the help everyone! It actually feels really great to have found this physics community, makes be love the subject even more :)
Marcargo.
= 41.8°
= 26.8cm
Where did the 30 come from?
he keeps changing the question! :biggrin:
= 26.8cm
shouldn't it be three significant figures ? :wink:
= 41.8°
= 26.8cm
Marcargo.
I have no idea where the 30 came from, but if the original question is taken as accurate (22cm), I get a different answer.
There is no need to do the arcsin and then take the tangent, you can use simple trig identities to manipulate it algebraically to get an exact answer of \frac{88\sqrt{5}}{5}, which can then be evaluated by calculator.
  • · Replies 16 ·
