Did hydrogren ICE cars not stall easily?
  • Thread starter Thread starter marellasunny
    Cars Ice
Engine stall occurs when an engine cannot adjust to increased load, often exemplified by releasing the clutch too quickly, which causes a drop in RPM and insufficient air for combustion. Hydrogen Otto engines, due to their high range of flammability, can operate at lower RPMs than gasoline engines, potentially reducing the likelihood of stalling. However, stalling is fundamentally linked to the engine's torque not meeting the load demands, regardless of fuel type. To prevent stalling, increasing throttle is essential to boost torque when load increases. Thus, while hydrogen engines may have different characteristics, the principles of torque and load remain consistent across engine types.
marellasunny
First,this is what I understood from theory:
If I understood the concept of 'engine stall' correctly,it occurs as a result of the engine not having enough time to adjust for a increased load.
As a practical example of engine stall,I consider the instance of 'letting go of the clutch pedal' too quickly. When I shift into first gear and let go of the clutch pedal all of a sudden,the engine stalls. I am guessing this is because the engine is 'suddenly' subject to a heavier load and its rpm dropped so low that it couldn't supply enough air to combust the fuel.
This brings me to the question of the hydrogen Otto engine cars. One of the main properties of hyderogen(this paper says so http://www1.eere.energy.gov/hydrogenandfuelcells/tech_validation/pdfs/fcm03r0.pdf) is its 'HIGH RANGE OF FLAMMABILITY'. This means that a hydrogen Otto engine car could run at lower rpms than a gasoline engine.So,I infer that hydrogen Otto engine cars didn't stall(back in the 60's) when you let-go of the clutch all of a sudden.
Is my inference valid? Does anyone here have experience with hydrogen-powered cars?
Any engine will stall when the torque become insufficient.
The stall is not caused by the fuel being unable to combust, it is caused when the load on the engine is larger than the torque the engine is providing, causing the engine to slow down until it stops. The way to fix this is to increase the throttle when increasing the load, such that the available torque increases as the load does. This would be just as necessary in a hydrogen car as in a gasoline powered one.
Understood.But,the full load torque curve of an IC engine is so much higher than the road resistance curve(i.e the curve calculated from the air,friction,incline resistance forces).
So from my understanding,at idle:the torque curve is the zero-load curve and when I suddenly let-go of the clutch,the road resistance curve with 1st gear would have exceeded the zero-load torque curve(hence causing the stall)?Is this reasoning valid?
Yes, the full-load torque curve is normally higher than the road-resistance, however, that full-load torque curve is generated at full throttle. You don't normally dyno an engine at idle - the engine stalls. If the engine torque combined with gearing cannot overcome the initial resistance then the engine will stall. You either need more torque, more gearing or more throttle (which generates more torque) to overcome resistance to motion.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
