Did I do this question correctly?
  • Thread starter Thread starter lanvin
The problem involves a box resting on a ramp inclined at 45°, with given mass and coefficients of friction. The task is to determine the largest force that can be applied upward along the ramp while keeping the box at rest.
  • Participants discuss the balance of forces acting on the box, including gravitational force and friction. There are questions about the correct application of friction coefficients and the definition of the coordinate axes used in the analysis.
Some participants have pointed out the omission of friction in the original calculations and questioned the use of the kinetic friction coefficient instead of the static one. There is ongoing exploration of how to correctly account for all forces acting on the box.
Participants note the importance of defining the coordinate system clearly and identifying all components of the forces acting on the box, particularly in relation to the incline.
lanvin
Question is:
"A box with a mass of 22kg is at rest on a ramp inclined at 45° to the horizontal. The coefficients of friction between the box and the ramp are µ(s) = 0.78 and µ(k) = 0.65
Determine the magnitude of the largest force that can be applied upward, parallel to the ramp, if the box is to remain at rest."
What I was thinking, is that if the object is at rest, then the net force on the x-axis is zero. So, the magnitude would be the same as the gravity parallel to the ramp...? My calculations:
(22kg)(9.8N/kg)sin45° - F(applied) = 0N
F(applied) = 152N
Is that right, or wrong? Hints or suggestions...?
You did not include the effect of friction.
Also, you should be clear when you say "x axis". What is the x-axis in your solution?
lanvin said:
Question is:
F(applied) = 152N
You forgot that the friction force on the box is also acting down the plane.
152N - F(f)
152N - (0.65)(22kg)(9.8N/kg) = 11.86N
did I do it right?
lanvin said:
152N - F(f)
did I do it right?
No. Why did you use the kinetic friction coefficient when it is given that the box is to remain at rest? Also, the normal force acts perpendicular to the incline; it is not equal to its weight. Have you defined your x axis, and identified all the components of the forces acting on the box along and perpendicular to the incline?
Without any added parallel or perpendicular forces, the force of gravity acting parallel to the ramp will move the box downwards. In this case, you're looking for a larger normal force to keep the box in place (think about adding pressure from a hand to prevent the box from slipping). Remember that F = uFN? Add an unknown force to the FN to symbolize the applied force added to the top of the box.
14K
36K
  • · Replies 44 ·
  • · Replies 56 ·
