Diffeomorphism invariance of metric determinant
Pacopag
Hi;
I am pretty sure that
sqrt(-g) is diffeomorphism-invariant.
I am wondering if all powers of this are diffeo-invariant too. For example, are
-g, g^2, etc. all invariants too?
If you want to use less cumbersome terminology, you can just say "is a scalar" rather than "is diffeomorphism-invariant." That's what "scalar" means in GR.
The answer to your question is yes, because any function of a scalar is also a scalar.
[--D'oh -- that was incorrect -- sorry! --]
Thank you for your reply. This is good news for me. To be sure, a valid action may take the form
<br /> S = \int d^4x \sqrt{-g}\left(R+\sqrt{-g}\phi^2\right)<br />
where
<br /> \phi^2 <br />
is a scalar
Is this correct?
The metric determinant is not a scalar. Think of the volume elements associated with (say) spherical and Cartesian coordinates in flat space.
Yes. You are right. The second term in my action does not work.
D'oh, thanks for the correctoin, Stingray. I was obviously not awake this morning when I posted #2 :-)
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
