Difference between 2-point and 4-point function in QFT
Higgsy
As I understand it, the 2-point fnuction is for 1 particle incoming, 1 particle outgoing. The 4-point function is for 2 particles incoming, 2 particles outgoing. Is this correct? So an N-point function describes N/2 incoming particles and N/2 outgoing particles?
Thanks!
The N-point function corresponds to N "external" particles, any of which can be incoming or outgoing. So the four-point function could be one incoming and three outgoing, or three incoming and one outgoing. Of course, if you're eventually interested in all external particles being on-shell to calculate amplitudes (which I assume you do here since you're trying to speak of particles incoming/outgoing), then you should conserve energy/momentum between initial and final states, which constrains certain configurations - e.g. you can't have two incoming and zero outgoing.
Sometimes we're interested in the N-point function off-shell, in which case it's not that meaningful to think of particles as incoming/outgoing.
Oh that makes sense. When would we be interested in the off-shell N-point function?
It is often the easiest way to renormalize the theory. You renormalize by setting some N-point functions evaluated at a specific value of "external" momenta to a renormalized coupling, and then replace all bare couplings with renormalized couplings. This is usually simplest with an off-shell choice, though you could choose them on-shell.
It's also useful because you can put your N-point function as a sub-diagram of a larger diagram, where your original N-point function is now integrated over some of its momentum values. There are also some advanced applications which use the analytic structure of N-point functions as a function of the external momenta.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
