Difference between Field and Fluid
Fields and fluids exhibit fundamentally different properties, with fluid mechanics and continuum mechanics being distinct disciplines. While fields can be described as vibrations of particles at high energies, this oversimplifies their nature and does not accurately represent their behavior. The analogy of space-time as a fabric influenced by gravity is a crude simplification that fails to capture the complexities involved. Applying fluid dynamics principles to fields is inappropriate, as they operate under different rules and equations. Therefore, it is not necessary or accurate to analyze fields through a fluid dynamics lens.
raknath
Hi
I was actually intrigued by the fact that most fields are nothing more than vibrations of particles at high energies; is it possible that fields could display properties similar to fluids. for instance let us take the Space-Time fabric,I believe it will be essentially visualized as a field, is it possible that the fabric actually behaves as a fluid.
Let us say that we take the classical model of a fabric and with gravity acting as a dead weight, which possibly explains the warping of space-time around gravity.
Crude example I know, but then would this fully explain the space time fabric.
Is it necessary at this stage to look at it from the fluid dynamics perspective
says who? and what does that even mean?
raknath said:
Hi
<snip>
Continuum mechanics (and continuum field theories) have been around since the 1700's, at least. GR is a classical continuum field theory, and it's nearly 100 years old. Fluid mechanics is a classical continuum field theory, and has been around at least two times as long as that.
Fluids obey completely different rules. You cannot apply equations of fluids to fields and vice versa. Example ;Bernoulli equations would not work for electromagnetism. You are oversimplifying things when you say that fields are nothing more than vibrations of particles and that spacetime is a fabric. Both statements are not accurate.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
