Difference between mechanical switch and a transistor switch?
A transistor switch, such as an npn transistor, can be activated by various stimuli, including sound, light, or electrical signals, without needing a mechanical switch. Bipolar junction transistors require a base current to draw collector current, enabling them to perform tasks like turning on an LED. They offer advantages over mechanical switches, such as faster switching speeds, silent operation, and durability, as they do not wear out. For example, a light detector can trigger a transistor to turn on a lamp at sunset, showcasing its practical application. Overall, while transistors are more complex to use than mechanical switches, they provide significant benefits in automation and efficiency.
user111_23
Doesn't a transistor switch need a mechanical switch? Otherwise, how does the transistor switch turn on and off? Does the switch have a "mind" of it's own?
A transistor switch, e.g., an npn transistor, can be triggered by a sound, light (photodetector), an electrical signal, or a radio signal (e.g., garage door opener).
Bob S
Bob S
Thanks for the reply. And if it isn't too much, how would an electrical signal alone switch a transistor?
I believe the answer to your last question can be readily found by considering the NMOS or PMOS transistor.
What did you have in mind?
Bipolar junction transistors draw very little collector current if they have no base current and draw a lot more current if they do have a base current.
So, to make them draw collector current you just need to produce a base current from some event.
If the event is very short (in time) then there are ways of producing a much longer time to turn a switch on or off for a longer time.
If they do draw a collector current, this can be used to do something useful. You might turn on a LED, for example.
The transistor has to be used in certain ways to keep it safe and so it works at all, so it is not as easy to use as a mechanical switch but it has many advantages.
It can be triggered by electrical signals.
It can switch much faster than a mechanical switch.
It is silent.
It never wears out.
A good example.. Suppose you want to turn on a light when the sun goes down.
You have a light detector driving a transistor switch which turns on the light. It isn't as simple as that, but you get the idea.
How would you do that with a mechanical switch?
I've got a little black box I am our sunroom, about 5 or 6 cm on a side. It plugs into the wall socket. It has a photodetector on it, and a knob labeled OFF ON 1 Hr 2Hr 4Hr 8Hr.
I use it to turn on a 120 Vac lamp for 4 hours after sunset every day.
Very convenient.
Bob S
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
