Different Tensions Acting on a Weight
  • Thread starter Thread starter student34
    Weight
The discussion revolves around calculating the tensions in a string supporting a mass at two different positions. Initially, T1 is defined as Fg multiplied by the tangent of angle θ, while T2 is calculated as Fg divided by the cosine of θ. Participants express uncertainty about the correctness of these equations and seek clarification on the forces and accelerations acting on the mass in both scenarios. There is a focus on resolving the forces to derive accurate equations for tension. Understanding the dynamics of the system is essential for solving the problem correctly.
student34
A 1 kg mass is hanging from a weightless string and is pulled by another weightless string to an angle of θ from the vertical. The string pulling on the weight is exactly perpendicular to Fg. When the horizontal string is cut, the weight swings 2θ. What is the tension (T1) in the string before the horizontal string is cut, and what is the tension (T2) in the string when the weight swings to 2θ?
T1 = FgTanθ, T2 = Fg/cosθ
T2 = 9.81N/cosθ
T1 = T2sinθ
I don't think either of the equations is correct.
What are all the forces and accelerations in the two cases?
Which way will you resolve them to extract the equations?
