Differential amplifier confusion (BJTs + Operational Amp)
59 replies · 8K views · last reply
Homework Helper
Find the Op-amp output voltage Vo in the following circuit.
Vout= Vin(1+Rf/R1) for non-inverting input.
Handwritten schematic of a BJT differential pair with 1k collector resistors to +15V, tail current source to -15V, and an op-amp stage with 1k resistors; node labels show 2V, 1.3V and 2V, and the output is marked V0 = ?.
Here is the circuit diagram provided in the book.
In the solution, the book has used the following approach (red markings in the image):
Input to the left transistor is 2V. Considering base-emitter junction drop to be 0.7V, the emitters are at 1.3V (left red arrow). Now, using the "virtual short" concept, the base of the right transistor is also pulled to 2V.
As the non-inverting terminal of op-amp is at 2V, using Kirchhoff's rules and the feedback equation, Vout=4V.
But how is the base of the right transistor pulled to 2V? Is the concept of "virtual short" really applicable here? As per my understanding, the right transistor should be cut off.
What is wrong here?
I would like a reference to the circuit, or to see the original page from the book.
That is correct for the circuit as shown.
cnh1995 said:
What is wrong here?
Everything. It seems like a useless circuit because there is no feedback from the op-amp to bias the transistor base on the RHS.
Will try to get the image of the problem. It is not a standard textbook, but a collection of problems in analog electronics (by a local publishing house). So the author/publisher might have carelessly printed this answer. I was helping a friend with his assignment and this problem is copied from his notebook.
Thanks for the response. My analog electronics is a bit rusty, so I posted here for confirmation.
If the two transistors are matched, the DC bias voltage, and the magnitude and direction of the current source are set correctly, then we should get the desired effect, which is the same base voltage for both transistors.
Where does the base current for Q2 come from?
To cnh1995:
"Now, using the "virtual short" concept, the base of the right transistor is also pulled to 2V."
Why do you expect that the base of T2 will be "pulled" to 2V ?
There is absolutely no reason for such an effect. The "virtual short" effect applies to active devices with very large gain and negative DC feedback only.
Yes, you are right, I missed that, the base current of Q2 can be provided by the ground resistor, but the input voltage must be kept below -0.7V.
Since this circuit requires an input voltage of 2V, a voltage source greater than 2V is required to supply current to the base of Q2.
I believe there must be three or more errors in the schematic.
The circuit would be more useful, easier to model and understand if;
The voltage source for the base of Q1 was negative two volts.
Or the transistors were N-channel FETs.
And the polarity of the conventional current source was reversed to become a sink.
I don't. :smile:
In your circuit, for a suitable bias point, the DC current through each transistor should be app. 5mA.
That means: A current source of 10mA in the common emitter lags.
In this case, the unsymmetrical voltage gain (collector T2) would be A=-0.01*10³=-10.
Hence, the input signal at T1 must not be larger than app. 100mV.
Question: What is the purpose of the opamp? To provide additional gain or something else? Perhaps it should be connected to the collector of T2?
The problem is not from any standard textbook. It is from a collection (booklet) of analog electronics problems for certain national/state level entrance tests in my country. So the purpose of the op-amp could just be to increase the difficulty level of the problem.
I ran a simutaion of this circuit on my phone and it shows that Q2 (right transistor) is indeed cut off.
Please, could you explain again? What is the purpose of the opamp?
Are you sure that it is not connected to the collector of T2?
Yes, it is connected to the base and not the collector of T2.
The purpose of the op-amp is not mentioned in the problem. Seems the book's solution is incorrect.
The only purpose of the op-amp is to be part of a problem. That problem appears to have been set by someone who did not understand electronics, or maybe a student copied the schematic wrongly.
There are too many possible reconstructions in the search space.
We need to see the original.
When the shown circuit is correctly redrawn the only purpose of the opamp could be to measure/verify the voltage at the base of T2 (it acts only as a buffer with a gain of two )
The first-stage two-transistor differential amplifier can be used as a wide-band high-impedance input follower, followed by a gain-of-two op amp in the second stage.
In any case, the original designer of the circuit may need to be consulted to understand its true function and purpose.
alan123hk said:
..., followed by a gain-of-two op amp in the second stage.
To me, "to follow" a stage means "to be connected to the output of that stage."
If the transistor difference amplifier of the front stage is only used as a wide-band high impedance input follower , it does not need any gain, so it does not need to be connected to the collector, but there is still a problem with my statement, if the output is only connected to the base, as shown in the circuit diagram , then its output impedance must be very high, and there is no driving force at all.
alan123hk said:
If the transistor difference amplifier of the front stage is only used as a wide-band high impedance input follower , it does not need any gain, so it does not need to be connected to the collector....
So what is the output node of the follower?
I must admit that I never have seen any BJT-based circuit where the base is used as an output.
I've also never seen a follower that uses the base as the output, and to be honest, the so-called follower is just my own assumptions or imagination, I may be wrong.
So I think if we need to find out the truth, maybe we need to find the original author.
I think what I actually meant was that the original author probably wanted to design a simple and accurate follower, but didn't think the transistor base could not be used as an output because it didn't have any driving force.
I try to avoid the abyss of silly circuits that were clearly designed by monsters.
"He who fights with monsters should look to it that he himself does not become a monster.
And if you gaze long into an abyss, the abyss also gazes into you."
Friedrich Nietzsche - Beyond Good and Evil - Aphorism 146.
LTspice schematic of a BJT differential pair with NPN transistors Q1 and Q2, a 10m current source I1 to Vee, resistors R1 and R2 of 1k to Vcc, an op-amp U1 output driving a 1k R4 and R3 divider to G2, and sine input V1 SINE(0 1 1k).
I have to agree with you. The more I looked at this circuit diagram, the more it felt incomplete, incomprehensible, and pointless.
This! It's actually a very simple circuit for inputs above 0V. It does nothing.
I think it could be interesting to discuss the properties of the shown circuit - in particular when it is compared with the classical four-resistor opamp based differential amplifier (advantages, disadvantages).
To close the loop, in the rational analysis of an irrational circuit, required that I also become crazy. To avoid furthering that process, I looked at the characteristic patterns in the OP circuit, while ignoring the detail and connectivity. Then I applied an "inverse acid-trip transform" to see what clean circuit concepts might have been present in the ancestral circuit, and how they might interrelate. The result was a neat and functional circuit, that features several different teaching concepts.
Go ahead, I hope to learn something.
Well - it was YOU who has proposed this circuit. Therefore, I think that - at first - you could say something about the usability of the circuit (a gain-of-two differential gain stage).
(I think, the circuit will only be stable for a relatively small opamp feedback factor (k<0.1) - depending, of course, on the opamp used.)
First, I assume that you mean the diff amp circuit that should have been shown, one that actually works. Look at @Baluncore's schematics for this.
Second, That diff amp stage IS Link Removed, in various incarnations. So I would reinterpret your question as what are the pros and cons of having a separate discrete input stage vs. integrating it with additional amplifier bits.
BTW, it sounds obvious that you would put it on the IC silicon, but there are times, like low noise circuits, when you mighty actually do what @Baluncore showed.
1.) First: Yes, of course. I don`t like to discuss circuits that do not work.
2.) Second: What I see in Baluncore`s contribution, is a differential amplifier with a single low-resistive opamp output. Such a differential amplifier can also be realized using an opamp and 4 resistors. That means - I like to compare two stand-alone units with each other.
In this context, I do not have any IC integration in mind.
Not sure what those words mean. But it doesn't matter since we both have the schematic to look at.
But, in the last 50 years, op-amps are ICs.
Anyway, what features do you want to compare? Cost, gain-bandwidth, input impedance, quiescent current, noise figure, reliability, stability, ... There are lots of specs for amplifiers. My guess is that IC amplifiers win in essentially all categories, which is why that's what everyone specifies. However, there are cases where an external discrete input stage has benefits, like low noise or high voltages. There are also many cases where a larger discrete output stage is needed.
Look at Link Removed. Everyone of those transistors has a purpose. They are put there to make it work better. So maybe your question is, regardless of implementation, why does one circuit have two transistors and the other has 20? My short answer reflects the ideal op-amp assumptions we all use: increased gain, increased input impedance, decreased output impedance. Also greater bandwidth and lower quiescent current. When you have multiple transistors to get the job done you can better optimise each for its job. The output stage is designed differently than the input stage in an IC, but in a two transistor diff amp, one transistor has to be good at both jobs.
