Differential Equations 2 order and objectives
layt
Help pls decide this Differential Equations!I did not coincide with the answer and in some no idea how to do! will be very grateful if you start a proper solution to Us
1) y(4)+2*a2*y''+a4*y= cos(ax)
2) y' = x + 1/y; y(0)=1
3) y' = 2*x + cos(y); y(0) = 0
4) y(x) - λ*(0 to pi)∫(x*sin(t)*y(t)*dt = 0 (find λ and y(x))
5) Parachutist descends on a parachute! Gravity parashyuta F1 = mg, and the force of air resistance F2 = k * v ^ 2, k = const find speed through chute t0 seconds after the shutter and the path traversed by S while!
1. Not clear. Check if you've typed it correctly. Isn't there supposed to be a term in y'? Instead there are 2 terms in y?
2. Express in homogeneous form. You might have to do a translation of axes.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
