What Are the Solutions for These Two Differential Equations?
In summary: Solution 1:The slope equation can be used to find the y-intercept (x-location) of a graphed function. Solution 2:The y-intercept can be found by solving for y in terms of x and \lambda. In summary, the equation of the tangent line to the curve is y = e^{\lambda x} and the point is (0,1).
Orion1
973
Find an equation of the tangent line to the curve:
[tex]xe^y + ye^x = 1[/tex]
at the point:
[tex]P(0,1)[/tex]
Find the values for [tex]\lambda[/tex] for which:
[tex]y = e^{\lambda x}[/tex]
satisfies the equation:
[tex]y + y' = y''[/tex]
I have been assigned these two problems, which are not covered for another 3 chapters.
I am uncertain how to solve problem 1.
This is my first attempt at problem 2, uncertain if this is correct.
[tex]e^{\lambda x} + e^{\lambda x} \lambda = e^{\lambda x} \lambda^2[/tex]
at the point:
[tex]P(0,1)[/tex]
Differentiate implicitly throughout the expression. You can do that right? You know, when you do so for:
[tex]xe^y[/itex]
you get
[tex] xe^y(dy)+e^y(dx)[/tex]
Right? Now do the rest, then solve for the quotient dy/dx.
[/COLOR]
Looks good. You can figure out what lambda is right?
The theorem of implicit functions solves the first problem.
Daniel.
Implicit Function Theorem...
The correct application of the Implicit Function Theorem:
[tex]\frac{dy}{dx} = - \frac{F_x}{F_y} = - \frac{e^y + ye^x}{xe^y + e^x}[/tex]
Solution 1:
[tex]\boxed{\frac{dy}{dx} = - \frac{e^y + ye^x}{xe^y + e^x}}[/tex]
Solution 2:
[tex]y = e^{\lambda x} \; \; y + y' = y''[/tex]
[tex]e^{\lambda x} (1 + \lambda) = e^{\lambda x} \lambda^2[/tex]
[tex](1 + \lambda) = \lambda^2[/tex]
[tex]\lambda^2 - \lambda = 1[/tex]
[tex]\lambda^2 - \lambda - 1 = 0[/tex]
[tex]\lambda = \frac{1 \pm \sqrt{(-1)^2 - 4(1)(-1)}}{2(1)} = \frac{1 \pm \sqrt{5}}{2}[/tex]
[tex]\boxed{\lambda = \frac{1 \pm \sqrt{5}}{2}}[/tex]
Nope
[tex] \frac{dy}{dx}=-\frac{e^{y}+ye^{x}}{xe^{y}+e^{x}} [/tex]
computed at the point (0,1) gives the slope [itex] -e-1 [/itex].
Daniel.
Slope formula:
[tex](y - 1) = (-e - 1)(x - 0)[/tex]
Solution 1:
[tex]\boxed{y(x) = -x(e + 1) + 1}[/tex]
Yes,it looks good now.
Daniel.
1. What are differential equations and why are they important?
Differential equations are mathematical equations that involve the rate of change of a function with respect to one or more independent variables. They are important because they are used to model and solve problems in many fields such as physics, engineering, economics, and biology.
2. How do I know which type of differential equation I am dealing with?
There are several types of differential equations, including linear, separable, exact, and homogeneous. To determine which type you have, you can look at the terms in the equation and see if they are directly proportional to the dependent variable, if they can be separated into different variables, or if they have specific forms that indicate a certain type.
3. What are the different methods for solving differential equations?
Some common methods for solving differential equations include separation of variables, integrating factors, substitution, and using series solutions. It is important to choose the appropriate method based on the type and complexity of the equation.
4. How can I check if my solution to a differential equation is correct?
To check if a solution is correct, you can substitute it back into the original differential equation and see if it satisfies the equation. You can also check the initial conditions, if given, to make sure the solution is consistent with the given information.
5. How can I apply differential equations to real-world problems?
Differential equations can be used to model and solve a variety of real-world problems, such as population growth, heat transfer, and motion of objects. By understanding the problem and identifying the relevant variables, you can set up a differential equation that represents the situation and use mathematical methods to find a solution.
  • Differential Equations
