Differentiatial equation
  • Thread starter Thread starter TimeRip496
TimeRip496
Does $$ ∅*(\frac{d}{dξ})=∅*(\frac{d1}{dξ}) $$?
If is true,
Does multiplying a function and a derivative equals to the derivative of that function? For e.g. $$ ∅*(\frac{d}{dξ})=\frac{d∅}{dξ} $$ where ∅ is a function of ξ
But isn't it supposed to be like this(based on the product rule), $$ ∅*(\frac{d}{dξ}) = ∅*(\frac{d1}{dξ}) = \frac{d}{dξ}*∅-1*\frac{d∅}{dξ} $$ ?
What if ∅ is a constant or is not a function of ξ?
Obviously no. Derivative symbol with nothing next to the right of it constitutes no meaningful quantities, no numerical value can be associated with it (if the variable is given a number), it's just an instruction to differentiate whatever stands on the right. If you put something to the right of a derivative (like you did in the RHS of that equation), you have given a numerical value to the entire expression.
Therefore
∅*(\frac{d}{dξ})\neq \frac{d∅}{dξ}
Therefore
Thanks!
But then how do I get from equation (12) to equation (13)? The only way I can do it is when
∅*(\frac{d}{dξ}) = \frac{d∅}{dξ}.
Where did you get source from? Is it the same source as the one with harmonic oscillator in another thread of yours?
Yes.
Source: http://vixra.org/pdf/1307.0007v1.pdf
I believe that's not the common and standard way to write the derivative of a function; in equation (12), ##\phi_0## should be on the right of the bracketed terms.
Likes TimeRip496
Ok thanks again for your help!
