Differentiation - Help, Please!
In summary: You have "Let the next "guess" to be "n2" (2 was suppose to be a subscript but I can't find it in the Latex Reference)" and then say "Slope: derivative of x^3 + 7x = 0 3x^2 + 7 = 0". (The slope is not the derivative of the function, it is the derivative of the function evaluated at the x-value.) That is not right. The slope is the derivative evaluated at the x-value. The slope of x^3+ 7x+ 3
1calculus1
39
Differentiation ---Help, please!
1. Homework Statement
1) Use Newtons Method to approximate the real zero of the function f(x)=x^3 + 7x + 3 = 0
2) The curve y = x^3-2x^2+x-3 intersects the curve y = cos(2x). If x = 1.8 is used as the first estimate then, using Newton's Method, what is the x-value or the intersection point, accurate to 4 decimal places?
3) A curve is given by y = a^3, where a = m^2(2m-1). Approximate the slope of the curve when m = 0.6543
4) If y = -4 / [tex]\sqrt[3]{x+5}[/tex], then dy/dx
5) Find an equation of the tangent line to the graph of f(x) = (x-1) / (x+1) when x = 1
2. Homework Equations
1) Newtons Method:
x = f(x) / f'(x)
Or Slope = Rise/Run
2) Newtons Method
x = f(x) / f'(x)
Or Slope = Rise/Run
3) y = mx+b
derivatives
4) Quotient Rule
(f'g-g'f) / (g^2)
5) Quotient Rule
(f'g-g'f) / (g^2)
y=mx+b
3. The Attempt at a Solution
1) x^3 + 7x = 0
Let the "guess" be "n"
3x^2 + 7 = 0
Rise: Plug in the "n" to the equation
n^3 + 7n = 0
Run: "n" subtract the "n2"
n - n2
Final formula:
3x^2 + 7 = n^3 + 7n / n - n2
*The answer should be this: (I was close but my rise is really off)
The first "n" is suppose to be a lower subscript. I can't find it here in the Latex Reference.
xn +1 = 2x[tex]^{3}_{n}[/tex] -3 / 3x[tex]^{2}_{n}[/tex] + 7
2) x^3 - 2x^2 + x - 3 - cos(2x) = 0
Slope = Rise/Run
Slope: Derivative of x^3 - 2x^2 + x - 3 - cos(2x)
3(1.8)^2 - 4(1.8) + 1 + sin2(1.8)(2)
Rise: Plug in 1.8 to the equation
(1.8)^3-2(1.8)^2 + 1.8 -3 - cos(2(1.8))
Run: 1.8 - x
Final Equation:
3(1.8)^2 - 4(1.8) + 1 + sin2(1.8)(2) = (1.8)^3-2(1.8)^2 + 1.8 -3 - cos(2(1.8)) / 1.8 - x
Simplify: 3.645639188 = -2.846026728 / 1.8 - x
-2.846026728 / 3.645639188 = 1.8 - x
1.8 + 0.780666045 = x
x = 2.680666046
The answer in the book is 2.0923.. So, do you think I should use my "x" to be the second trial and do the whole equation again from the start to get the 2.0923?
3)
a = m^2(2m-1)
(0.6543)^2(2(0.6543)-1))
a= 0.13211428
y = a^3
Therefore...
y = 0.13211428^3
y =0.002305946
I'm stuck. Please help?
4) ((0)([tex]\sqrt[3]{x+5}[/tex])) - ((-4)(1/3(x+5)^-2/3)) / ([tex]\sqrt[3]{x+5}[/tex])^2)
Simplify: ((4)(1/3(x+5)^-2/3) / ([tex]\sqrt[3]{x+5}[/tex])
Then I don't know how to simplify it much longer.. My simplifying skills has gone bad, I guess. Help, please?
5) Get y-value, plug in the x-value which is 1
1-1 / 1+1 = 0
(1,0)
Do quotient rule on the equation...
(1)(x+1) - (x-1)(1) / (x+1)^2
Simplify...
(x+1) - (x-1) / (x^2 + 2x+2)
Plug in the x-value which is 1 to get the slope.
(1+1) - (1-1) / (1^2 +2(1) + 2)
2 / 1+2+2 = 2 / 5
Slope = 2/5
y=mx+b
0 = 2/5(1) + b
0 - 2/5 = b
-2/5 = b
Final equation...
y = 2/5x -2/5
Although it seems like I did everything right, my final equation seems to be incorrect from the answer in the book which is x-2y=1
THAT'S ALL FOR NOW. I'll continue more questions later on if I find any that bugs my mind. But for now, I need to go to church so in the meanwhile, PLEASE HELP? =/
Anyone there?
Please?
At least just help me with question #3.. PLEASE?
1) Newtons Method:
x = f(x) / f'(x)
Or Slope = Rise/Run
That's the definition of "slope", not "Newtons method". Newton's method says [itex]x_{n+1}= x_n- f(x_n)/f '(x_n)[/itex]
[/itex]2) Newtons Method
x = f(x) / f'(x)
Or Slope = Rise/Run
3) y = mx+b
derivatives
4) Quotient Rule
(f'g-g'f) / (g^2)
5) Quotient Rule
(f'g-g'f) / (g^2)
y=mx+b
1) x^3 + 7x = 0
3x^2 + 7 = 0
n^3 + 7n = 0
n - n2
Final formula:
You understand, don't you, that a "real zero of the function f(x)=x^3 + 7x + 3 = 0" is a number? Applied to this problem, f(x)= x3+ 7x+ 3 so the derivative is 3x2+ 7. Newton's method says that if xn is a close to a solution then [itex]x_{n+1}= x_n- (x^3+ 7x+ 3)/(3x^3+ 7)[/itex] will be closer. If you take x0= 0, then [itex]x_1= 0- (3/7)= -3/7[/itex] or about -0.4286, then [itex]x_2= -0.4181[/itex], etc.
Slope = Rise/Run
Run: 1.8 - x
Final Equation:
x = 2.680666046
I think what you are doing is using the idea behind Newton's method rather than Newton's method itself: Yes, you are trying to solve [itex]f(x)= x^3- 2x^2+ x- 3- cos(2x)= 0[/itex]. [itex]f '(x)= 3x^2- 4x+ 1+ 2sin(2x)[/itex]. If you choose 1.8 as your x0, then [itex]x_1= 1.8- ((1.8)^3- 2(1.8)^2+ 1.8- 3- cos(3.6))/(3(1.8)^2- 4(1.8)+ 1+ sin(3.6)= 2.1091[/itex], not the "2.6807" you got. Try it again and then continue until you get two consecutive values that are equal to 4 decimal places.
3)
a = m^2(2m-1)
a= 0.13211428
y = a^3
Therefore...
y = 0.13211428^3
y =0.002305946
You weren't asked to find y, you were asked to find the derivative of a: use the chain rule: dy/dm= (dy/da)(da/dm). To find da/dm, I think I would go ahead and multiply: a= m2(2m-1)= m3- m2
I think you will find it much easier to write y= -4(x+ 5)-1/3 and use the 'power rule' rather than using the quotient rule.
1-1 / 1+1 = 0
(1,0)
Simplify...
No, (x+1)2 is NOT "x2+ 2x+ 2! I think you would find it better just to leave the denominator as (x+ 1)2.
2 / 1+2+2 = 2 / 5
Slope = 2/5
As I said, your denominator is wrong. (1+1)2= 4.
y=mx+b
0 = 2/5(1) + b
0 - 2/5 = b
-2/5 = b
Final equation...
y = 2/5x -2/5
Yes, see my comments above.
1. What is differentiation?
Differentiation is a mathematical process of finding the rate at which a function changes. It is used to find the slope of a curve at any given point and is an important concept in calculus.
2. Why is differentiation important?
Differentiation is important because it allows us to analyze and understand the behavior of functions, such as finding maximum and minimum values, determining increasing and decreasing intervals, and solving optimization problems.
3. How do I differentiate a function?
To differentiate a function, you need to apply the rules of differentiation, which include the power rule, product rule, quotient rule, and chain rule. These rules allow you to find the derivative of a function with respect to its independent variable.
4. Can differentiation be used in real-life applications?
Yes, differentiation has many real-life applications in fields such as physics, engineering, economics, and biology. For example, it can be used to analyze the motion of objects, optimize manufacturing processes, and model population growth.
5. Are there any resources available to help with differentiation?
Yes, there are many resources available to help with differentiation, such as textbooks, online videos and tutorials, and practice problems. You can also consult with a math tutor or teacher for additional help and clarification.
