Differentiation of a Piecewise Function
GreenPrint
I have a graph of velocity vs time and was asked
"Describe how the velocity changes over the time interval of the problem"
how do I do this all I have is the graph that is not defined by a function... well I can make my own strangely all it is is a bunch of linear lines put together that looks like this
.._
sort of like a hill were it dy/dx is positive and constant for bit then is zero for a while then becomes negative so I wanted to find the second derivative of this, acceleration, not exactly sure how to do this with a piecewise funciton this is what it is now? I have to come up with the derivative of each part and then what should i do to come up with the derivitive of the whole graph
Plot the derivatives of each part on the graph. It may not be continuous, but it is a piecewise derivative. Can't expect continuity.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
