Difficult nuclear physics exercise
The discussion revolves around analyzing a table of decay rates from a mixed radioactive sample to determine the number of different nuclides and their half-lives. Participants suggest plotting the data for better visualization and using least squares fitting to model the decay rates with exponential functions. One user successfully identifies that the sample consists of two nuclides using MATLAB's curve fitting toolbox. There is also mention of a numerical Laplace transform as a potential method, although some participants express confusion about it. Ultimately, the focus is on fitting the decay data to derive meaningful insights about the sample's composition.
broegger
The activity from a mixed radioactive sample is measured at different times and given in a table like this:
Time (h)...Decays/sec
0.0 ...... 7500
0.5 ...... 4190
1.5 ...... 3100
12.0 ..... 280
I am now supposed - based on this table - to determine how many different nuclids the sample consists of along with their half-lives. How can I possibly extract that information uniquely from that table (the numbers in the table aren't exactly the right ones, since I can't remember them).
maybe the table needs some explanation, because of the crappy layout; the left-hand column is the time in hours and the right-hand column gives the corresponding activities (I haven't written the complete table).
First, I would suggest making a plot of the data to get a feel for it.
One approach is to do a least squares fit but you'd have to do it several times for varying numbers of isotopes.
You might also try doing a numerical Laplace transform. I'm not sure if it can be done but ideally you would see a spike for each nuclide.
Thanks for answering.
I'm not sure; do you mean I should try to fit the data to functions like this:
f_n(t) = A_1e^{\lambda_1 t} + A_2e^{\lambda_1 t} + \ldots + A_ne^{\lambda_n t}
for various n (corresponding to the number of different isotopes) and see which fit is the best. If so, how can I do this?
I have no idea what LaPlace transformation is, so I don't think this is what we're supposed to do.
Tiiiiide! ;)
Yes, that is what I mean with regard to fitting the data.
Also, if you have no idea what a Laplace transform is then nevermind!
Weee! I managed to show that n = 2 using Matlabs curve fitting toolbox. Thank you very much for helping me.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
