Difficulty finding integral answer to set function
wown
Note: as i was typing this post, i think i figured out the answer but i want to confirm.
Question:
let A denote the set of points that are interior to, or on the boundary of, a square with opposite verties at the points (0,0) and (1,1). let Q(A) = ∫∫dydx
if C, a subset of A, is the set {(x,y): 0 < x/2 ≤ y ≤ 3x/2 < 1}, compute Q(A)
Solution:
I kept getting 1/2 as the answer, but i think my limits of integration were wrong. is the following correct?
^{2/3}_{0}∫^{3x/2}_{x/2}∫dydx
this setup gives the answer as 2/9... unfortunately i do not have the correct answer which is why i needed to verify.
The question is not completely clear. For x > 2/3 is anything included?
This would involve: x/2 < y < 1.
Unfortunately, i typed the question verbatim and not sure how to respond to you.
note that the 2/3 upper limit on x was defined by me. I figured that y <1 (from y ≤ 3x/2 < 1). so therefor x cannot be more than 2/3, since y must also be less than 3x/2. for x> 2/3, y>1. e.g. when x=1, y=3/2.
does that make sense?
No. Your condition x/2≤y≤3x/2 for x > 2/3 restricts y to x/2≤y≤1, but does not remove it altogether.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
