Digital Angle Measurement for Rotating Solar Cells
  • Thread starter Thread starter Henkjaap
    Angle Measurement
The discussion focuses on finding a digital device to measure the angle of rotating solar cells for optimal alignment with the sun. The context involves a system where solar panels rotate around a fixed axis, and participants explore various measurement options suitable for this application.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests using a rotary encoder or a digital level, emphasizing the need to calibrate the zero position based on a chosen datum.
  • Another participant expresses concern about the feasibility of attaching a rotary encoder due to the design of the system, where the solar panels float in water and may slide on the axis, complicating the attachment.
  • A different participant proposes using a simple potentiometer to measure angular displacement by correlating it with changes in resistance.
Participants present multiple competing views on the best measurement approach, with no consensus reached on a single solution.
Challenges include the physical constraints of the system, such as the diameter of the axis and the floating nature of the solar panels, which may affect the stability and accuracy of measurement devices.
Henkjaap
I am looking for a digital device that is able to measure the angle of a rotating device.
It will be used to align rotating solar cells with the sun. These cells are attached to a flat panel, that is fixed in the center with an axis, so only circular movement is possible. The panel needs to rotate from East to West (approximately) to optimize energy production. The position of the sun can be calculated, but the position of the solar cells need to be measured.
I tried to use a fluxgate compass first, but this device is not accurate enough and needs to much time to stabilize.
So what I'm looking for is an alternative to measure the angle between the solar cells and the axis.
Any suggestions?
Thanks!
It seems to me your options are a rotary encoder or digital level. I would use a rotary encoder and calibrate your zero with respect to whatever vertical or horizontal datum you want.
Thanks for your reply.
I was thinking about this too at first. The problem is, the (fixed, in the ground) axis diameter is 0.3m and the solar panels are rotating around this axis. The panels are floating in water (the system is placed in a swimming pool), so the panels are sliding up and down a bit on the axis. This makes the attachment of a rotary encoder very difficult and fragile.
How about a simple potentiometer? Calibrate your system to correlate a range of angular displacement to the change in resistance.
  • · Replies 52 ·
