Dilating or expanding a closed ball in Riemannian geometry
The discussion revolves around the concepts of expansion and dilation in the context of Riemannian geometry, particularly focusing on the implications of these terms when applied to a closed ball that is changing over time. Participants explore the definitions and contexts in which these terms are used, as well as the potential ambiguities in the original question posed by the thread starter.
  • Some participants propose that expansion can be defined using set theory, where an object is considered expanding if the set of points it covers at a later time properly contains the set at an earlier time.
  • Others argue that the concept of dilation needs clarification, questioning whether it can be equated with expansion in time, especially when considering time as a fourth dimension.
  • A participant suggests that the original question may be misusing terminology, indicating that the answers provided might not align with the intended inquiry.
  • There is a discussion about the context of metric expansion, with some participants noting that it is typically associated with cosmology and may not apply directly to Riemannian geometry as implied by the original post.
  • Some participants express that the question posed by the original poster lacks clarity and may lead to different interpretations among respondents.
  • It is noted that terms like "ball" or "sphere" are defined within sets that have a metric, emphasizing the importance of context in the discussion.
Participants generally do not reach a consensus on the definitions of expansion and dilation, with multiple competing views remaining regarding their applicability and interpretation in Riemannian geometry.
The discussion highlights ambiguities in terminology and the need for clearer definitions, particularly in relation to the context of Riemannian versus Lorentzian geometry. There are unresolved questions about the assumptions underlying the definitions of expansion and dilation.
johnconner
Hello. If a closed ball is expanding in time would we say it's expanding or dilating in Riemannian geometry? better saying is I don't know which is which? and what is the function that explains the changes of coordinates of an arbitrary point on the sphere of the ball?
Expansion is a concept that does not even require topology, let alone geometry, to define it. All we need is set theory. An object is expanding if and only if for any two times t1 and t2 such that t1 < t2, the set of points covered by the object at time t2 properly contains the set of points covered by the object at time t1. So the geometry does not affect whether the object is judged to be expanding.
thank you. then what is dilation? when we can use that? if we consider time as the fourth dimension, then can we say expansion in time is a dilation?
Is this off the back of your thread in cosmology? If so, I rather suspect you're still misusing terminology, so the answers you get may well not be to the questions you think you are asking.
Okay, but this was posted under "Differential Geometry", which assumes we are talking about some sort of metric expansion.
Does it? Metric expansion is typically used in cosmology, but it then refers to a particular family of spatial submanifolds of a Lorentzian manifold. The OP seems to imply talking about Riemannian geometry. To me it just seems as if the OP has not written a well defined question and may think he is asking something but in reality that something is going to be interpreted differently by different people. There is a need of context from OP (ie, I agree with #4).
Cosmology doesn't have a monopoly on the term "metric"! In any case, "ball" or "sphere" are only defined in sets with a metric.
This is not the point. The point is that the question is ambiguous.
  • · Replies 40 ·
9K
